O2 Sensor Code
Old Jul 25, 2020 | 04:28 PM
Zena8956's Avatar
Zena8956
Default O2 Sensor Code
My check engine light for my o2 sensor came back not too long after I replaced it and cleared it. I drove it for about 30 minutes and it came back. Anyone know why or how to fix this?
Old Jul 28, 2020 | 08:31 AM
jhc's Avatar
jhc
General & Tech Moderator
This car is known to be pretty picky with electronic parts. Did you replace with Denso or Hitachi? Last I heard Bosch will work also. If you got a generic I'd replace with one of these.
Is it upstream/sensor 1 or downstream/sensor 2?
Old Jul 28, 2020 | 09:15 AM
Zena8956's Avatar
Zena8956
It’s an NTK sensor it’s upstream top drivers side
Old Jul 28, 2020 | 09:16 AM
Zena8956's Avatar
Zena8956
it’s an upstream sensor and I used NTK
Old Jul 28, 2020 | 10:08 AM
jhc's Avatar
jhc
I could be wrong but I think that's the problem. If you want to save $120 you could swap that sensor to the opposite bank, clear the code and see if the code follows the new location. Alternatively you could get an OEM ( I think Rockauto.com has them cheap) and be done with it, assuming it's not a harness problem.
Here you go, the upstream Denso is $69.00
https://www.rockauto.com/en/catalog/...2)+sensor,5132
GL!
Zena8956
Jul 23, 2020 02:12 PM
350Z Project X
Oct 17, 2015 05:16 PM
m3pk350z
Mar 12, 2013 11:04 AM
crsracing19
Apr 14, 2011 02:27 PM
