04 350z sputtering
Old Apr 8, 2022 | 08:42 PM
Zachary69's Avatar
Zachary69
Default 04 350z sputtering
So I just replaced the plugs hoping that would f&x the problem. It didn’t! The car sputters/misfires when idling and when under load. It sounds kind of like running out Of gas but more severe. I don’t know what to do it has a new air filter. No check engine light. It seems like when it’s under load it just cuts power for a second when it sputters. Any ideas?
Old Apr 9, 2022 | 11:49 AM
travlee's Avatar
travlee
Master
2 coil pack plugs are swapped
Old Apr 9, 2022 | 01:21 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Good thought. 4 & 6 usually are the culprits.
But.... if the problem existed before pulling plugs, most likely misfire or vacuum leak. Pull the codes and look for P03xx (and other) codes. Could just be a bad coilpack, which it often times is.
dktechguy112
Feb 6, 2014 11:02 AM
topside09
May 25, 2011 07:13 AM
AmuseMyZ
May 19, 2009 12:19 PM
Fairlady_z33
Sep 5, 2005 08:59 AM
