Hello, the left one works on and off, is on for a week then goes off for a couple of days, any way I can fix it probably I don't have to remove the center console any help will be appreciatte.
All 3 gauges are one unit. If you're good with soldering electronics, you can remove it, find the broken trace and re-solder it. If no, you'll have to replace the entire unit.
Thank you I8acobra, why is working on and off? to do what you are suggesting I need to remove the panel and find out the broken trace in the circuit
Thx
