Wired in new fuel pump with relay now my fuel guage isn't working.
Old Apr 8, 2025 | 03:52 PM
Bloodgame's Avatar
Bloodgame
Default Wired in new fuel pump with relay now my fuel guage isn't working.
Trying to get the fuel guage working again. I accidentally wired it wrong and I'm sure I shorted the ground wire for the fuel temp sensor and the fuel level sensor. I'm trying to trace down where this ground goes. From the diagram that everyone uses for the relay addition, it says it goes to ecu. I looked through the wiring diagram and maybe I'm just not understanding something because I just cannot figure out where to look. There are no fuses popped. I tested the fuel level wire to a body ground and I get voltage , when I test it to the ground wire for those sensors I get nothing. Where's does this ground wire go? I got 50$ cashapp for whoever can help me figure out this issue.
Old Apr 8, 2025 | 09:21 PM
Whiskers1996's Avatar
Whiskers1996
Blk/Yellw = To Fuel pump relay.
Red/Blk = To Unified Meter & AC Amp
Gry/Red = To ECU (107)
Old Apr 9, 2025 | 06:11 AM
Bloodgame's Avatar
Bloodgame
So it changes from black/red to red/black at the plug upfront on the main harness that runs by the drivers seat? Also , how does the secondary fuel level sensor tie into this equation?
Old Apr 9, 2025 | 10:50 AM
Whiskers1996
Here is the sub..
Red/blk = fuel sensor ground. To ac amp.
white/blk = fuel sensor. To ac amp.
and yes, the wire color changes.
Old Apr 24, 2025 | 07:09 AM
Johnnytwo's Avatar
Johnnytwo
Have you had any luck with this? I'm currently having a similar issue.
Old Apr 27, 2025 | 07:32 AM
Bloodgame's Avatar
Bloodgame
Yeah i ended up wiring a new ground to the ac amp. Got my fuel guage back but temp sensor still buggy. It quit immediately throwing a code and just stays in pending. Been such a pain in the butt.
tazmanjoe
Jul 18, 2021 03:11 PM
DEMoLITIoN
Jun 1, 2013 07:10 AM
mx594
May 27, 2013 10:32 AM
INTIMAZY
Jun 2, 2012 08:50 PM
bbs350z
Dec 5, 2010 09:27 AM
