problem with electrical i belive
Old Aug 25, 2004 | 06:58 PM
kosta157's Avatar
kosta157
Default problem with electrical i belive
I own a 2004 silverstone ZR i have 8,700 miles on it and today while i was making a right turn my VDC, check engine light, and slip lights all turned on at the same time and i loss all power to the car i could not go faster the 5mph, i pulled over to the side and shut the car off, then back on and all lights dissapered except the check engine. this is at 9AM around 1PM i took lunch from my work check engine light was off, left my work at 5PM and as i was making a left this time same exact problem occured. Anyone have any idea what the hell is going on with my car???? i will be going into the dealer on tuesday.
Old Aug 26, 2004 | 02:58 PM
FLZ's Avatar
FLZ
Had the exact same prob for three months. Dealer could not figure it out. New computer,new throttle body, then new harnesses. On the final shot before Lemon Law arb. The Nissan North America Specialist found the Oxygen Sensor connector was loose. Good as new ever since. Good Luck. If that's not your problem, I'll be praying for ya, Dave Please let me know how things go. It was a b*tch of a time for me drbtc@adelphia.net
Old Sep 1, 2004 | 11:59 AM
350Z_Redline's Avatar
350Z_Redline
I'm having the same damn problem. The strangest thing is that my car will not rev past 6K rpms. It gets to 6K and the rev limiter kicks in. The first time I hit the limiter I just thought that I wasn't paying attention. The second time I watched as the tach needed bounced around at 6K and then my slip, vdc and ses lights came on. There was a noticeable loss of power and I immediately pulled over and shut it down. After I restarted the ses was still on but the power had come back. My dealer recently reinstalled my stock flywheel and clutch when installing my 2nd tranny under warranty. I previously had the JWT flywheel/clutch and thought that maybe the ECU just hadn't adjusted to it yet. So I disconnected the battery to clear the code. After clearing the ses light it still hits the limiter at 6K but the lights hadn’t come back on until yesterday; when I was racing a C5 of all times. Now the ses is still on and I’ll be taking it to the dealer once my axels come in from back order. I did recently change to 225/40 and 245/40 series tires but the stager is close enough to stock that it shouldn’t be causing a problem. I’m fed up with all of these stupid problems and will be getting rid of this car within the next 6 months.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
