Water Leaking into Car - Need Help
Old Oct 13, 2004 | 07:43 PM
peterhong's Avatar
peterhong
Default Water Leaking into Car - Need Help
I just noticed after another carwash that my drivers side floormat was wet around the gas pedal. Upon further search, I noticed others with aftermarket alarms had this problem as well. I've actually located where the water is dripping in but need help as how to seal it.
If you look at the picture I've taken from under the steering panel by the pedals, the water is leaking from the circle rubber stopper where the red/black siren wire is going through. Directly under the hood, there is another similar rubber stopper which was not drilled into, but seems like it was popped out a little on top which is causing the water to come in through the opening into the rubber seal in the cabin.
Now my question. I can't seem to get to that rubber stopper under the hood (short of removing the engine) and I cant seem to push it in by brute force either. Can I just take some sort of rubber sealant spray and spray the surrounding area where it was popped out, or is there another solution to this. Quite concerned because when the water comes dripping into the cabin by the pedals, there are a bunch of wires that can possibly short if they get wet.
Old Oct 13, 2004 | 08:05 PM
peterhong's Avatar
peterhong
I can see the picture isn't coming out for some reason although I've attached it. I'll try again.
Old Oct 13, 2004 | 08:06 PM
peterhong's Avatar
peterhong
Sorry for the poor quality, it had to be compressed to fit, but hopefully you can see what I'm talking about from this pic.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
PureR3d
Sep 10, 2015 06:23 PM
