Car will not start/please help!
Old Nov 13, 2004 | 01:13 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Angry Car will not start/please help!
So I moved my car last night, cranked just fine. I walk outside to crank it. Negative... so I think hmmm battery must be dead. Nope, its fine. Checked fuses...blah blah blah anyway...
A friend and I push started the car. Started just fine, no problems there so nothing in the fuel system. I thought it was the starter. So I took the car down to a shop and wait for over an hour just be told they cant check anything but the starter and battery because of my "modified wiring."(ie stereo system) Starter is fine. Checked the clutch switch, think its fine.
Next...
Take apart the dask to find what I think is the starter wire coming from the key. I turn the key to start it and indeed it gets 12v from the key switch. I then go down to the fuses and connect my multimeter across the terminals to see if power is running through the fuse area. Nope. Hmmmm... now what? Relay. The relay is clicking just like it should. so nope.
Im lost now. I need a wiring diagram but nobody has taken the time to post up the service manual or I just suck at the internet and cant find it. :s
somebody please post up the diagrams I need! Im not going to the stealership. I will fix this. :|
please please help me
Old Dec 1, 2004 | 12:18 PM
NOR-CAL Z TUNER's Avatar
NOR-CAL Z TUNER
did you check the starter wire at the starter ? also try and cycle the alarm system. also there is a switch on the clutch pedal check to make sure that is connected, if you wish to call
call ted at scott performance 408 988-2233
Old Dec 1, 2004 | 05:56 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
it was a brake wire...so stupid
Old Dec 9, 2004 | 11:36 AM
tcn75's Avatar
tcn75
brake wire ???
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
