Finally got my last night!!!! I was soooooo excited, until a little bird doodoo splatter on my car on my way home last night!!! Of course I immediately went straight to a gas station to clean that off!!! So far I've got nothing but compliment about the car, it is awesome!!!
Originally posted by 350zSpeedRacer Many people have been calling to get the part numbers since there seems to have been a change in December. In fact, there's a thread in the Problems section, probably near the top, since this has been such a big problem.
Right now, NNA doesn't have a REAL fix, so dealerships are doing alighnments and rotating tires, but it doesn't do anything. I would suggest reading up on everything that's been done so far, and maybe getting in touch with NNA to voice your concerns. Not all cars are having a problem, but just in case.
I hope yours turns out fine!
Has anyone able to get the part number? and do you meant the part number for the Spring? Because I've spoke to several Field Region Rep (at the NNA and not the toll free number) and they told me that whatever fix that needs to be done, it has been corrected it at the port for all the new car that comes in. But I'm not sure how far back that would take you to, on when the car was built and all that? But If y'all need to find out the number on the parts, I could sure do that!!! also, i've talk to the Regional Service Trainer at NNA, and he also indicated that with switching tires from side to side (you can't rotate them, because they are directional) and with the alignment that should cure it. I'm also kind of wondering could of it might have something to do with the weather change, since the tire expand and retract with the temperature change? Huh, just a guess?
Well, I'm sure will looking for it, if something start to happen on mine!
Originally posted by SHIFT_Z
[B]Has anyone able to get the part number? and do you meant the part number for the Spring?
Check with Krinkov. I think he's the one who got the part numbers for before and after the change. And if memory serves, Nissan went with a different spring instead of shock. But I can't remember 100%.
