FS: V1 Rays Wheels with Hoosier A6 295/30 Autocross Tires - $750
Old Jul 18, 2013 | 05:02 PM
RockoS13's Avatar
RockoS13
Default V1 Rays Wheels with Hoosier A6 295/30 Autocross Tires - $750
(Rockville, MD) - This is a set (2 front, 2 rear) of V1 Rays Engineering 18" wheels from a 2003-2005 350Z Track model with Hoosier A6 Autocross tires (r-comps) mounted. The tires are 295/30 and have usable tread left (maybe 1/3 on rears, 1/2 on fronts, but I prefer the buyer judge). Not willing to separate at this time.
Center caps are included. These would make a great autocross setup for a 350Z or G35 and would fit several other cars as well.
Wheel condition: Slight curbage on one wheel. Also, the factory paint has some kind of discoloring and I am not sure if it would polish out. (See pics)
The wheel specs:
114.3 x 5, 18"
hub center bore: 66.06
Front Size: 18x8.0 Offset: +30mm Weight: 18.19lbs (without tire)
Rear Size: 18x8.5 Offset: +33mm Weight: 18.62lbs (without tire)
Tires: Hoosier A6, 295/30 all around. Build dates are 0811 and 0111. They've been kept indoors and wrapped. Not used on street.
Thanks for looking!
Old Jul 18, 2013 | 06:36 PM
Destroyeron's Avatar
Destroyeron
295s are really wide for an 8" aren't they?
Old Jul 19, 2013 | 06:36 AM
RockoS13's Avatar
RockoS13
For Hoosiers and autocrossing, it's a actually perfect fit, especially if you are running in the stock class. Rules restrict you to stock-size wheels but have no restrictions on tire sizing. The 295s fit well and also help with gearing in the Z. They don't rub, either!
I've never tried 315s but it might be possible .
I would not use 295/30-18 on an 8" wheel in normal street driving, though.
Old Aug 17, 2013 | 10:16 AM
RockoS13's Avatar
RockoS13
Bump! Still available.
Old Aug 31, 2013 | 06:27 AM
RockoS13's Avatar
RockoS13
sold.
