G35 Turbonetics Single Turbo Kit INTRODUCTORY HOLIDAY SPECIAL!!!
Old Dec 5, 2005 | 02:09 PM
dynamic6er's Avatar
dynamic6er
Default G35 Turbonetics Single Turbo Kit INTRODUCTORY HOLIDAY SPECIAL!!!
Everyone at Altered Atmosphere would like to announce the release of the Turbonetics Single Turbo Kit for the Infiniti G35! We’ve sold and installed many Turbonetics Single Turbo Kits for the 350Z and are extremely excited to finally be able to offer this upgrade to our G35 customers.
To start things out for the Holiday’s we’ve put together two dynamite turbo packages for the G35. In addition to offering special pricing on the Turbonetics Single Turbo Kit, we’ve included some important upgrades we developed after encountering several items installing these kits on the 350Z. These upgrades perfect the kit and make installation a breeze for our 350Z Turbonetics customers – so we’d like to offer the same upgrades for the G35!
AS A SPECIAL added BONUS we are going to include the AAM Oil Pan Spacer Kit at no additional cost! The AAM Oil Pan Spacer was specifically designed for our customers with the Vortech and Turbonetics forced induction kits to eliminate oil leaks, retail the factory oil pan (no need to modify), and increase oil cooling capacity for better reliability.
With the Turbonetics kit specifically you have to tap the factory oil pan for the turbocharger oil return line. Not only does this make it extremely difficult to return your G35/350Z back to stock down the road if you so choose, it is extremely common for tapped oil pans to develop leaks. The AAM Oil Pan Spacer eliminates both these problems. It does so by coming pre-tapped for the Turbonetics turbocharger oil return line – no cutting and tapping necessary! Additional benefits of the AAM Oil Pan Spacer are added oil capacity, increased oil cooling, and easy integration of an oil temperature gauge sensor as it comes with additional pre-tapped provisions for future leak-free upgrades.
What’s included in the kit and install price:
Infinity G35 Single Turbo Kit – 60-1 Turbo No Catalytic Converter
Turbonetics Kit Includes:
  • Turbonetics 60-1 Ball Bearing Turbo
  • Spearco Intercooler Large W.A.V.E. Technology Core with Cast End Tanks
  • Dual Fan Intercooler Shroud
  • Turbonetics Tuned Upgraded ECU with Larger Injectors
  • Turbonetics AF-1 Air Filter
  • Turbonetics Evolution Wastegate
  • Turbonetics Raptor Blow Off Valve with Polished Discharge horn
  • Black Chrome Mandrel Bent Aluminum Intercooler Piping
  • Polished Mandrel Bent Stainless Steel Exhaust Pipes with V-band Connections
  • 3.0" Polished Mandrel Bent Stainless Steel Downpipe
AAM Oil Pan Spacer Kit Includes:
  • Billet Aluminum CNC Milled Pan and Oil Pump Pickup Spacer
  • Extended Metrics Cap Heads Screws and Washers
  • Blue Anodized AN Fittings for Return Line Ports and Oil Temp Sensor Port
  • AAM Spec Stainless Return Line Kit with AN Fittings Available as an Upgrade Option
Installation Includes:
  • Custom Installation by our Experienced Techs at our facility in Gaithersburg, MD
  • One(1) OEM Nissan Oil Filter (Oil Included with Turbonetics Kit)
  • Six Quarts Case TS-1 Synthetic Turbo Oil
  • One(1) Baseline Dyno Run after Installation to Ensure Full Function, Provide Complete A/F, and Power Readouts
Retail + Regular Install
$8000.00
Special Limited-Time Installation Offer
$6499.99
!A Savings of over $1500!
(If you are doing your own installation, call or e-mail Sales@alteredatmosphere.com for special pricing!!!)
Turbonetics Single Turbo Stage 2
For those of you that would like a little extra power and do not want to be limited by the Turbonetics ECU Flash (1. many 350Z’s experience a hesitation around 6200-6,500rpm from running too rich with the Turbonetics programming and 2. the ECU Flash does not allow the end-user or tuner to make necessary fuel/timing adjustments) we have the AAM Turbonetics Stage 2 upgrade available.
The AAM Turbonetics Stage 2 upgrade replaces the Turbonetics ECU Flash with the TurboXS UTEC fuel controller and map sensor upgrade. The UTEC fuel controller is the ultimate user tunable engine management system available for the 350Z and G35. We became familiar with the UTEC a while ago where we were asked to help dyno test the UTEC on a 350Z making over 500rwhp. We were so impressed with the results of the UTEC that we made an arrangement to test one on our shop 350Z. In summary, the 350Z/G35 UTEC can be described as a piggy-back engine controller (ie. GReddy E-Manage Ultimate, Unichip, Split Second) under vacuum that becomes a stand alone engine management system under boost (full unrestricted control of fuel and timing). Basically the fuel computers we’ve previously used modify signals to manipulate the factory ECU into delivering different amounts of fuel and timing to the car. This does work but is not ideal as the factory computer can change its base mapping = the car will run with different fuel and timing than setup on the dyno and different fuel and timing than wanted. The UTEC eliminates this potentially engine damaging problem by bypassing the ECU altogether under boost. Under boost the UTEC takes complete control and directly sends fuel and timing commands to the injectors and ignition coils – the factory ECU is taken out of the loop and therefore cannot make any adjustments!
The UTEC also had many other features including the ability to eliminate the MAF for more air flow, advanced knock control, and complete data logging that can be viewed on your laptop computer.
Infinity G35 Single Turbo Kit – 60-1 Turbo No Catalytic Convertor
UTEC Programmable Fuel Computer with Turbonetics Turbo Kit Base Maps
UTEC 5-Bar Map Sensor Upgrade Kit
Upgrade to 550cc Injectors for $549
  • UTEC Turbonetics Kit Base Map
$9049.00
$7499.99
