Cusco Sway Bar.
Old May 4, 2006 | 02:47 PM
Kirkster's Avatar
Kirkster
Default Cusco Sway Bar.
Well guys the Cusco Sway bar came in on tuesday but I had to leave for Denver for a couple of days. I Just got home to play with the new toy.
Good quality, Solid not hollow, and Beefy...
Now on to the directions...
Looks like this may void my warrenty...
And for the most important part...
Hummm... 120% or 137% stiffer...
Oh yea we are going with 137%
Old May 4, 2006 | 03:42 PM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
LOL. Yeah crank that thing up!
Old May 4, 2006 | 03:43 PM
spacemn_spiff's Avatar
spacemn_spiff
It looks like you got the front one only, stiffer front usually means more understeer, is that what you want ?
Old May 4, 2006 | 08:07 PM
Kirkster's Avatar
Kirkster
Yes and no... The stiffer front will induce a bit more understeer but it will also preserve what little front camber that we have since there will be less body roll.. So for autoX the stiffer front bar will be better.
Old May 5, 2006 | 06:05 AM
spacemn_spiff
Never been to autox, but I prefer a little oversteer than understeer.
Old May 5, 2006 | 06:16 AM
05-Z's Avatar
05-Z
I think it also says "this message will self-destruct after 10 minutes"
Sways might be the next purchase....definitely a good mod.
Old May 5, 2006 | 07:27 AM
TENGAI's Avatar
TENGAI
The nice part about understeer is that it only takes a little heel-toe action to correct...
Old May 5, 2006 | 08:45 AM
superchargedg's Avatar
superchargedg
Damn Noobs
whats wrong cant you read that it says if you install it in the usa your car will self destruct,but if you hurry up and get the car over to japan and install it there all will be ok.lol.
Old May 5, 2006 | 01:42 PM
Kirkster's Avatar
Kirkster
Heh... The car has not self-destructed yet... It only took me about 40 min to install the bar, it would have been 30 but I had to take off that pesky undercover with umteen screws.
I must say after a quick drive that I do feel a good bit of improvement in the handling as I have a lot less oversteer now (if you can believe that). When I first put on the Konis I had gobs of oversteer (probably don't need half stiff in the rear) but after putting on the front sway most of it is gone. I have not pushed it hard enough to see if I have more push in the front yet but we will see.
2 on the difficulty scale.
Old May 5, 2006 | 02:36 PM
StarcraftBW's Avatar
StarcraftBW
the sway looks like a champ......but you should get both front and rear
Old May 5, 2006 | 03:33 PM
Kirkster's Avatar
Kirkster
Rear is not allowed in autoX
At least not in the stock class...
Old May 9, 2006 | 07:25 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
stiffer front does wonders for turn in.....there is no understeer to be felt on a street driven car
hulkout
Apr 28, 2017 09:00 PM
StateNuke08
Oct 31, 2015 05:01 AM
RiujinZero
Sep 25, 2015 01:19 PM
Calinismo350z
Sep 14, 2015 04:04 PM
