Motorsports The Z in its Natural Habitat
Upgrade Brakes Question
Old Dec 26, 2002 | 12:19 PM
C Ray Z's Avatar
C Ray Z
Question Upgrade Brakes Question
I have a 350Z touring that I want to add a upgrade brake kit for auto crossing and track running. Does anyone know if Stop Tech type brakes can be substituted for Brembro brakes and still satify the stock requirement? Or are only Brembro's acceptable.
Old Dec 27, 2002 | 05:44 PM
Maximam's Avatar
Maximam
You would have to use what came factory.
As for braking, if you are only autocrossing, I don't think you will need better brakes. Roadracing WILL require better brakes!
Old Dec 27, 2002 | 06:23 PM
negcamber's Avatar
negcamber
Changing to Brembos for autox would really blow you out of a competitive class for the Z. Try just upgrading pads, which is legal in stock class. Carbotech makes some great autox pads and they say they can make pads for any car, even those not listed on their website catalog...the Z isn't listed yet.
Old Dec 27, 2002 | 07:19 PM
C Ray Z's Avatar
C Ray Z
Default Brembro's on the Track
Since the Brembro's come standard on the track, aren't we able to upgrade to them on touring models?
350Z is not limited to which model we purchased when running in a stock class, is it?
Educate me, some one who knows the rules. I tried to read this in the SCCA web site but it wasn't real clear.
Old Dec 28, 2002 | 03:04 PM
negcamber's Avatar
negcamber
Default Re: Brembro's on the Track
For SCCA, you are limited to what came on your version, either standard or as a factory option (not dealer options). This is so competitors cannot mix and match the best parts from the various versions of a model of car. Imagine if the base model weighed 200lb less than any of the other Zs and the automatics had a much shorter final drive...if that were the case you would have to buy a Base and then swap out for the Track brakes/wheels/etc, and buy and install the automatic rear end, etc, etc, etc. That would make being competitive very expensive.
Autox is run what you brung racing, and tries to keep costs down for competitors.
Old Jan 3, 2003 | 05:02 AM
MaddMatt's Avatar
MaddMatt
What he said. You can do it, but you would have to install EVERYTHING from a track model that your car didn't come with.
I've seen this done to other cars (turning a base Miata into an R model) at a great expense. It would be quicker, cheaper, and FAR less hassle and work just to sell you touring model, and buy a track model.
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
dcains
Nov 11, 2015 11:36 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
