Removal of vq Heads..
Old Dec 5, 2008 | 03:11 PM
steven350's Avatar
steven350
Default Removal of vq Heads..
Im looking forward to porting my valves, etc. i want to remove my heads off my motor..
biggest concern: does the motor need to come out of the car in order to remove the heads?
Old Dec 5, 2008 | 05:58 PM
XM 1's Avatar
i would say no...but it makes things much easier
Old Dec 5, 2008 | 06:06 PM
westpak's Avatar
westpak
SFZCC
it is a pain no matter what, you have to remove the cams to get to the head bolts, and to get the cams off you have to remove the cam sprockets and to remove the cam sprockets you have to remove the front timing cover and to remove the cover you have to remove the crank pulley and accessories..... basically a PITA I wouldn't do it unless the engine is being disassembled for some reason, but yes it can be done in the car
Old Dec 5, 2008 | 08:49 PM
go-fast's Avatar
go-fast
beware..... if you have no experience with 4 valve heads you stand a good chance of hurting flow.the "hog 'em out" mentality will give you nothing but regret.
Old Dec 6, 2008 | 11:44 AM
steven350's Avatar
steven350
appericiate the advice/help so much thanks
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
