problems with underdrive pulleys?
Old Jan 11, 2009 | 08:51 AM
nissannube's Avatar
nissannube
Default problems with underdrive pulleys?
i havent done too much research into the setup, but last night i was looking at a thread on here and someone mentioned that they had heard too many horror stories to use a crank underdrive pulley. what all issues have any of yall had or heard? this was to be my next upgrade, but if it is going to be more trouble then it is worth i will look another route
Old Jan 14, 2009 | 08:22 AM
gothchick's Avatar
gothchick
They're not dampened for starters -- Also the pulley key can strip if it's not reinforced. Both can mess your crank up pretty bad. Just stick with oem...
Old Jan 14, 2009 | 10:52 PM
zettahertz's Avatar
zettahertz
you may not experience any problems for a while (if they do cause problems). But I'm staying away from them for my Z.
Here's some good read:
http://www.atiperformanceproducts.co.../101/index.htm
http://www.dinancars.com/bmw/technia...armonic-damper
http://www.suprasonic.org/public_htm...atedamper.html
The choice is yours.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
