High-Comp Time!
Old Apr 7, 2010 | 08:28 PM
S12 driver's Avatar
S12 driver
Looks like a nice build. Has anyone build an e85 only high comp VQ35 yet? A lot of the Honda n/a builders are getting some crazy hp out of the k series by using e85.
Old Apr 8, 2010 | 04:28 AM
SGSash's Avatar
SGSash
Vendor - Former Vendor
Thanks Guys!
Regarding the compression ratio, the pistons have an 11.5cc dome, which if I am correct will result in around a 12.1:1 compression, not the actual target 12.3. The little bit of material around the spark relief is another 0.3~ cc's.
From my understanding, I should be seeing roughly 5% power for each point of compression (up to a point, of course), so the 2 points could in theory net 30 wheel. I don't expect that and will be happy with anything more than 15.
E85 is a great idea, I don't know much about it. For endurance racing I believe the fuel consumption is higher so that might be a problem for our current 1.5hr stint strategy, the cell just isn't big enough. I'd also have to check the bladder in my cell and make sure that it's ok to use with alcohol.
Old Apr 8, 2010 | 04:34 AM
Spork's Avatar
Spork
In for results!
Old May 10, 2010 | 08:48 PM
kacz07's Avatar
kacz07
Are there results?
Old May 12, 2010 | 02:24 PM
11B Z Noobie's Avatar
11B Z Noobie
I am hanging up my NA build on this. I gotta see what you can do first! Nice write up in the June Modified BTW!!!!
Old May 14, 2010 | 07:21 AM
SGSash's Avatar
SGSash
Thanks!
Well you guys would be amazed, the higher compression pistons yielded absolutely no gains what-so-ever. Infact, the dyno plot basically was a carbon copy of what it was with the stock engine.
Two tests were performed:
Stock intake manifold, throttle body and Skunk2 spacer
AND
Our aluminum box with open 3.5" hole in the top.
Both plots look identical to the power you've seen before, which was quite amazing. The only changes other than the pistons and rods were Mark II racing fuel and NGK racing spark plugs that have more clearance to the plug.
The engine has now developed a nasty vibration or flex that is causing the flywheel to actually hit, and destroy the crank angle sensor only at very high rpm under very high load!
It's really quite amazing. Other than that the engine runs perfectly, has great oil pressure, doesn't smoke etc.
The flywheel has been off and inspected, we even did some tests to try and figure out exactly when the flywheel is "growing" and it seems to be happening ONLY above ~4500rpm.
I tuned the traction control on the Motec M800 and god damn the car sounds amazing at full load 7000rpm with 50% ignition cut, you just have to hear it. Ahhhh
And then right after that glorious moment, the crank angle sensor is destroyed and she just silently rolls to a stop. It's really sad.
Old May 14, 2010 | 07:40 AM
kacz07's Avatar
kacz07
Interesting results. Bummer about the sensor. Keep up the good work!
Old May 14, 2010 | 08:04 AM
SexyRob's Avatar
SexyRob
that is crazy... what does it mean!??
Old May 14, 2010 | 08:33 AM
Zazz93's Avatar
Zazz93
Weird problem... bad flywheel encoder maybe, or bad seating on the crank?
Old May 14, 2010 | 11:18 AM
kacz07's Avatar
kacz07
Means that the higher compression doesn't add anything. I wonder if, aside from different wall to piston clearances, aftermarket pistons and their compression ratios make any difference on FI vehicles then.
Old May 14, 2010 | 11:43 AM
SexyRob's Avatar
SexyRob
kacz07: well I got that.... I just thought that with N/A builds compression was part of the HP gain. With other engines adding compression usually boost HP, so the fact that the VQ35DE doesn't respond to raising compression is odd. Does this mean there is something else restricting the engine, that we don't see,because its not taking advantage of the added compression?
this is on stock cams right? I'm guessing cams are the key to unlocking these engines.
*edit*
these pistons 95.5 or overbore to 96mm??
Old May 14, 2010 | 12:28 PM
kacz07's Avatar
kacz07
*edit*
Wasn't trying to be an idiot, just a segue into the question I asked. If the cams can get enough air in there, then maybe there are some gains to be had. I have the big cams, headwork, valves, and higher compression, I need the INTAKE now!
Old May 14, 2010 | 12:51 PM
MREDDLE's Avatar
MREDDLE
I'm sorry if you said this already. What flywheel are you using? Are you sure the balancing was done correctly and well enough? I can't imagine a tune can be any good with machanical problems. I am by no means talking bad about you or the machine shop/builder. I'm just raising the question and getting insight.
Old May 22, 2010 | 04:24 PM
kgkeen101's Avatar
kgkeen101
Yeah, mechanical related to a compression bump? Balancing in question.
Old Jun 14, 2010 | 06:39 AM
PlatinumSR20's Avatar
PlatinumSR20
any updates?
Old Jul 5, 2010 | 09:53 PM
NiZMo1o1's Avatar
NiZMo1o1
Originally Posted by Nathan
It will be very interesting to see the power increase that these pistons achieve.
In 2003 I had a talk with the boss of Nissan Motorsport South Africa.
They were the builders of the factory Paris-Daker rally raid Pathfinders.
In the conversation he said that the DE made good power up to 12.5 CR with very little to be gained above this. He also said to use the 46cc Nismo heads to increase the CR so as to keep the original combustion chamber & piston design.
Because of the intended use of the motor ( Long distance, high revving & high temp desert racing ) they settled on 11.0 CR but still made over 400 HP @ the flywheel by using Jenvey ITB's, Pectel ECU & some very high lift cams.
do you have any links to this or pics ?
were the jenvey dealer in the US here , the same set on Ivory and Kgkeen VQs.
I wouldnt mind seeing more images pop up of the setup
Old Jul 5, 2010 | 09:56 PM
NiZMo1o1's Avatar
NiZMo1o1
Originally Posted by SGSash
T
its becomming more and more stations here in FL with E85 , it runs alot cooler but you need to drain the tank and also upgrade the fuel lines and run bigger CC injectors for it, which I assume you've already done on a race car, but the downside is dentation and be able to tune it , I belive the Pro-EFI now have the sensor for E85 as well.
nice build , cant wait to see the final results
Old Sep 28, 2010 | 08:49 AM
  #38
SGSash's Avatar
SGSash
Hey Guys,
Sorry for the lack of updates.
It turns out the flywheel had cracked at the starter / trigger
So that is what was chewing up the sensors. Repaired the flywheel and the car has been running well since then! Set a few lap records at local time attacks, and am on my way to a 1:26 at Mosport.
We just finished modifying this upper plenum which found some extra power, comparable to the carbotron intake. Car is now making 331whp, the hood closes and it has a throttle body - unlike some of our other tests! So this is legit horsepower, although I was wishing with the compression I would be at 340whp by now.
Short Fly-by Video:
Old Sep 28, 2010 | 08:56 AM
  #39
kacz07's Avatar
kacz07
Nice plenum. Is there equal airflow over all cylinders? It looks like the passenger side would get more air.
Old Sep 28, 2010 | 12:23 PM
  #40
copec's Avatar
copec
Thats pretty cool! do you have more details on the plenum? Are you running a spacer and also that modified elbow?
