A/C Delete
Old Apr 24, 2011 | 07:37 AM
blackwolf1778's Avatar
blackwolf1778
Default A/C Delete
well ive searched before i posted and couldnt find anything so im posting this to ask
What size of belt do i need to bypass the A/C compressor
i live 30 min from the parts house so it will save time and money if i just knew what size lol thanks evreyone in advance
Old Apr 24, 2011 | 12:06 PM
shakuya88's Avatar
shakuya88
The ac belt is separate from the main belt. Just pull both off, then only install the other. This will not drive the A/C any more. Free mod for you! (not sure why, you want to do this, but to each his own.
Old Apr 24, 2011 | 01:25 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
I did that 'mod' on my 90 300ZX. It's just less power drain on the engine. I hardly ever use the AC. I like driving with the windows down. Feels better that way.
Old Apr 24, 2011 | 02:55 PM
INTIMAZY's Avatar
INTIMAZY
Kinda pointless mod unless you REALLY need the weight savings (there isn't much anyway)
The pulley has very little drag when the compressor is off and the compressor also automatically turns off when you go WOT.
Old Apr 30, 2011 | 05:28 PM
jwttz's Avatar
jwttz
I f you remove all the a/c compnents i.e compressor, condensor, and lines it well take about 25 lbs (est) from the front which is pretty good. Also there is less paristic drag on the motor.
Bigsyke
Sep 11, 2015 06:19 PM
SunsetZ
Feb 10, 2003 09:20 AM
ezspeed
Jan 20, 2003 08:42 AM
