What are the best NA mods ? help!
Old Sep 24, 2011 | 07:04 PM
YFQ370z's Avatar
YFQ370z
Default What are the best NA mods ? help!
i have 350z 2008 VQ35HR ,
i want to put cp pistons comp. 11.1 , egle rods , ARP studs , tomei cams 280 , valves springs , long headers , injen air intake , hks catback , pulleys , acl bearings , clutch stage 2 and tune !
what also can i put ?
do you have a better idea ?
and how much do you think these parts will give me in the dyno ?
Old Sep 24, 2011 | 07:38 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Whoa!
I get the first to say I best you won't do it!
Old Sep 24, 2011 | 07:41 PM
skeetzee's Avatar
skeetzee
Long tube headers and test pipes???
Old Sep 24, 2011 | 07:48 PM
YFQ370z's Avatar
YFQ370z
Originally Posted by KingBaby
Whoa!
why ?!
Old Sep 24, 2011 | 07:57 PM
KingBaby's Avatar
KingBaby
Hardest Setting
It's gonna cost and after you research you'll understand that the NA road is a long and unforgiving road!
Search please!
Old Sep 24, 2011 | 08:00 PM
YFQ370z's Avatar
YFQ370z
i just want to add 70 hp to the car ,,
Old Sep 24, 2011 | 08:09 PM
KingBaby's Avatar
KingBaby
Hardest Setting
NOS is your best bet for under $1300!
Why's posted in your first post is nothing but $$$&&&&$$$$ in labor/parts....
Old Sep 24, 2011 | 08:35 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
depends on your budget...if you want to build the motor for a mild gain in hp go for it but it definitely wont be cost affective.
don't bother with intake, the stock intake is still the best for hp numbers.
if it was me i would just do test pipes or long tube headers, exhaust, tune.
Old Sep 24, 2011 | 09:01 PM
YFQ370z's Avatar
YFQ370z
so i just put long headers + stage 2 cams + valves springs + filters drop in + tune !
that the best right ?!
Old Sep 24, 2011 | 09:22 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Best for what? Keep reading
Old Sep 24, 2011 | 09:47 PM
YFQ370z's Avatar
YFQ370z
best for good gain and less money ,,
whats the best stage 2 cams ?
Old Sep 24, 2011 | 09:51 PM
Viksz33's Avatar
Viksz33
KW V3, Hotchkis sway bars, nismo lsd, 4.083 FD, K&N filters, tune, good brake pads, lines, fluid and tires.
Old Sep 24, 2011 | 09:53 PM
Lakeside's Avatar
Lakeside
70 WHP is not asking alot! Many have come close to making up for drivetrain losses with bolt-ons and tune! Several of us are in the 292-300WHP and 250-262 WTQ range.
I'm not sure what support you will be able to obtain in Kuwait?! GTM works with oversea's enthusiasts! I would contact them. I personally would do a stroker build if going down the NA route. Get a GTM stroker kit, Tomei cams, long tube headers, exhaust, Injen CAI's, UpRev tune, oil cooler, nismo finned diff cover, OS Giken twin disk clutch, a true LSD diff and some 3.9-4.08 gears and you will have a beast!
Sounds like you have no budget in mind! hehe
Zim
Old Sep 24, 2011 | 11:08 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Man...This damn iphone makes me look like I have dyslexia when typing!
Old Sep 25, 2011 | 03:06 AM
JCITY's Avatar
JCITY
Question Whats your objective?
Reading this laundry list of parts,I'm trying to figure out what is your main objective?First,how much are you willing to spend?Reading between the lines,
"give me on the dyno",it looks like the goal is more HP...?How much HP?
If so,you could eliminate all the internal parts and get a single turbo set up
(Momentum & others) and get up to around 400hp.Its gonna cost 6K + install,ship tune--maybe you got over 8k in the mod plus you external exhaust
etc stuff.
Old Sep 25, 2011 | 04:30 AM
Classy's Avatar
Classy
If you are dead set on doing this, go for it, with an HR, I can almost guarantee you will be over the 300whp mark. BUT, in saying that, you will spend in the neighborhood of $6-8k US to get there IF you do most of the work yourself. Now, if you decided to put a turbo on, and conservatively set it up for around 400hp, you will probably spend about the same amount if you wheel and deal and do the work yourself.
I myself went NA, but it was because I had a lack of funds to go further....
Old Sep 25, 2011 | 05:42 AM
YFQ370z's Avatar
YFQ370z
whats the 4.083 FD ? i didnt understand ?
for what is that ?
Old Sep 25, 2011 | 05:48 AM
YFQ370z's Avatar
YFQ370z
etc stuff.
hmm i want hp in the dyno like 320 to 340 hp ,, i want my car for drift and also a little street racing and normal use ,, so i want it NA
Old Sep 25, 2011 | 05:52 AM
YFQ370z's Avatar
YFQ370z
Zim
the 3.9-4.08 gears , it smaller than the normal gears right ?
Old Sep 25, 2011 | 06:36 AM
Classy's Avatar
Classy
You will lose top end, but you will gain alot of acceleration
