DE vs Ported DE vs HR Head Flow Results
Old Mar 5, 2013 | 06:05 AM
OPSash's Avatar
OPSash
Default DE vs Ported DE vs HR Head Flow Results
Hi Guys,
I just had some stock HR heads ported. As you may remember I had the DE and ported DE heads also flowed a year or so ago, so this gives us good data to compare to:
See the exhaust flow comparison and the rest of the post on the original article:
http://www.onpointdyno.com/?p=2817
Old Mar 5, 2013 | 07:39 AM
wird06's Avatar
wird06
Good information. I like seeing this kind of hard numbers on the forum.
Old Mar 5, 2013 | 07:43 AM
redline06's Avatar
redline06
damn whats with the yelling
Thats awesome info Sasha, good to see youre still doing work I take it your ported HR heads are gonna go on your racecar which you will then dyno and show us if it made power ? if so i cant wait lol
Old Mar 5, 2013 | 09:27 AM
XChacalX's Avatar
XChacalX
Originally Posted by andre12031948
I don't know who Sash/Sasha is. I don't try to bash posts. I'm just trying to find a few more HP for my car. That's pretty much it.....
then I suggest you to look for his future post because that will help you a lot if you intent to do something similar
Old Mar 5, 2013 | 09:41 AM
andre12031948's Avatar
andre12031948
His meaning Sasha? What shop is this? I've heard the name many times, but due to my many political postings, & of course the other daily routine of living life, leaves me with very little time to investigate or even read entire posts(not the right thing to do)
I'll look/read anything that SHOWS me a few H.P./increase of performance for an HR Z.
Do something similar? Porting exhaust to match headers/gaskets? I'm open to everything/anything.
Old Mar 5, 2013 | 09:50 AM
OPSash's Avatar
OPSash
Sorry guys, I didn't have the HR heads ported - I meant to write that I had them flow tested.
I will run the engine stock and see the power it will make with ITBs, big cams and proper headers. Then I will build the engine, and port the heads.
Old Mar 5, 2013 | 02:36 PM
2TH PWR's Avatar
2TH PWR
Thanks for posting up your info Sash.
Cool of you to share.
Old Mar 5, 2013 | 03:15 PM
andre12031948
I'm assuming this will be the HR engine. If that's the case, good luck & I'm looking forward to seeing the results.
Old Mar 5, 2013 | 08:47 PM
blue350zed's Avatar
blue350zed
That's some good info, Sash. Wish I would have done a before and after of the port work on my HR. Really seems to help but I don't have any numbers to back it up.
Old Mar 5, 2013 | 09:14 PM
terrasmak's Avatar
So does anyone know if HR heads will work on a DE yet.
Old Mar 6, 2013 | 05:20 AM
wird06's Avatar
wird06
I need a like button for this^^^^.
Old Mar 7, 2013 | 03:36 AM
2TH PWR's Avatar
2TH PWR
I know xchacalx just put a hr head on the 3.7 vhr block. Maybe he would know
Old Mar 7, 2013 | 03:52 AM
XChacalX's Avatar
XChacalX
I dont know for sure but I was told No , the HR head would not match with the DE block.
Old Mar 8, 2013 | 06:38 PM
terrasmak's Avatar
I know the head gaskets match so they will bolt to the block. Timing cover, cams, etc etc
Old Mar 9, 2013 | 06:50 AM
OPSash's Avatar
OPSash
I have been told it IS possible to mount HR heads on the DE block.
I have not tried it myself however. You would need to machine the HR heads for the cam triggers in the rear, and the valve covers / intake manifold of course is all different.
Not sure if the exhaust ports are in the same relative position or not.
Old Mar 11, 2013 | 05:28 PM
johnwigs's Avatar
johnwigs
09+ Maxima is an HR head on a DE block, but it is a front wheel drive set up... there is a way to do it on a rear drive :wink:. I'm not going to tell anyone, it is kind of proprietary info
Old Mar 13, 2013 | 05:44 AM
OPSash's Avatar
OPSash
Oh my, you're special! I wish I knew those kinds of secrets so I could taunt the rest of My350z with "proprietary" information!
Old Mar 13, 2013 | 10:27 AM
INTIMAZY's Avatar
INTIMAZY
Old Mar 13, 2013 | 11:41 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Lol. If hr heads worked I'd try them on my DE. maybe by the time I get my next motor this top secret info will be out
Old Mar 13, 2013 | 04:06 PM
doshoru's Avatar
doshoru
