Will installing Darton sleeves hinder my cooling for Raod Course???
Old Jul 31, 2014 | 05:47 PM
jonnyidfw's Avatar
jonnyidfw
Default Will installing Darton sleeves hinder my cooling for Raod Course???
I have a set of New DArton Sleeves and I am wondering if they will hurt or help my cooling for Road Course use?? Thanks in advance for any info!
Thanks,
Jonathan
Old Jul 31, 2014 | 09:06 PM
Glover41's Avatar
Glover41
I don't think so, they're built to hardcore your engine in first place lol.
However, since you're tracking your car then you may consider an oil cooler, it's recommended whether u're sleeving ur cylinders or not.
Old Aug 1, 2014 | 05:53 AM
jonnyidfw's Avatar
jonnyidfw
Thats what I was thinking as well, However I have read that a few FI Guys say that their engine gets a little hotter under WOT, quicker than without them...... I agree an oil cooler is a Must have item... Thanks for the input Sir.
Old Aug 1, 2014 | 07:57 AM
Classy's Avatar
Classy
Darton sleeves are extremely unnecessary. Appropriate modifications will do fine. FI guys don't even run them anymore below 650 hp...
Old Aug 1, 2014 | 10:08 AM
jwttz's Avatar
jwttz
Are you talking about sleeving a stock block?
Old Aug 1, 2014 | 10:11 AM
Classy's Avatar
Classy
That is exactly what sleeves are for...
Old Aug 1, 2014 | 12:27 PM
jonnyidfw's Avatar
jonnyidfw
I know they are a little overkill, however, I have them so I was thinking about getting them put in while the block is at the machine shop getting assembled.... I was just concerned with overheating or higher operating temps during Road Course Racing.....
Old Aug 1, 2014 | 12:28 PM
jonnyidfw's Avatar
jonnyidfw
Not to mention I will also be using 2 stage 200 shot (total) of NOS for occasional drag racing, as I have a few friends who enjoy Drag racing @ Texas Motorplex.... Thanks for the Input guys.
Old Aug 1, 2014 | 07:25 PM
jwttz's Avatar
jwttz
I mean sleaves with the stock internals sassy.
Old Aug 1, 2014 | 08:20 PM
jonnyidfw's Avatar
jonnyidfw
Stock Internals? This motor has forged rods & pistons, billet girdle, PPE LTH, JWT C8 cams w/springs, +1mm Valves, head porting, 3.5in MAF & Intake, NWP TB & Kinetix V+ Plenum, etc, etc..... So no, it us not a stock internal engine...
Old Aug 2, 2014 | 08:43 AM
jwttz's Avatar
jwttz
Ah, I was reading it wrong for some reason. I thought you were going to tear down your engine and just put sleeves in there cause you got a deal on them. Didn't make any sense.
Old Aug 2, 2014 | 09:50 PM
jonnyidfw's Avatar
jonnyidfw
Well it would have helped had I put the mods that will be joining the sleeves!!LOL
Old Aug 2, 2014 | 10:30 PM
jerryd87's Avatar
jerryd87
simple flow chart, are you going to exceed 800 whp? no? dont do it, yes? sure but be very very picky who does it. alot of people have had issues with overheating and sleeves, i cant think of a single shop that would recommend road racing and sleeves for that very reason
Old Aug 3, 2014 | 06:13 PM
Nathan's Avatar
Nathan
Jonny
You make no mention of bore size.
The Datron sleeves can be bored out to 101mm to give a total displacement of just over 3800cc but the problem then is head gasket sealing. There is not much left between the cyls & to my knowledge only cometic make a 101mm Head gasket & it does not have a stopper ring.
If your not going to boost it into the stratosphere or increase the bore size I see no reason to use sleeves.
Old Aug 3, 2014 | 08:19 PM
jerryd87's Avatar
jerryd87
its 100mm, and cometic changed awhile ago, they have been stopper style for years now.
doing a built engine without FI is 100% a complete waste your spending just as much money for a fraction of the output, even with a stroker your still going to make less then stock block FI guys for ALOT more.
Originally Posted by Nathan
Jonny
Old Aug 3, 2014 | 09:48 PM
Nathan's Avatar
Nathan
Page 84 Cometic catalogue.
Vq35 de Largest Head Gasket listed 101.5mm Type MLS (non stopper)
Part #C4380-030.
100mm Gasket is available in MLX (stopper) which is what you would use if you saw the need to fit sleeves to get bigger capacity without a crank.
Agree with Jerry & others, that FI is by the far the biggest Bang for Buck.
As the OP does not say how serious he is going with Road Corse it may be that the class he picks may prohibit FI.
The list of mods does not include pistons & rods. IMO an absolute necessity & a far cheaper option than Datron sleeves
Old Aug 3, 2014 | 10:46 PM
jerryd87's Avatar
jerryd87
the 101.5 mm headgaskets arent even worth mentioning, they will never be used in a build unless the engine builder is an idiot. the largest bore the darton sleeves support is 100mm, so the 100mm is the largest you would use everything under 100mm is available in stopper style as well as ive built engines with them.
im not even aware of any place that keeps the 101.5mm on the shelf
Part #C4380-030.
Old Aug 4, 2014 | 12:11 PM
jonnyidfw's Avatar
jonnyidfw
As far as the bore, it is a stock bore.... I would like to go FI, however it is not exactly well know for reliability when road course racing....
Old Aug 4, 2014 | 12:20 PM
Conway_160's Avatar
Conway_160
This is just my .02 Unless you plan on making 850+whp don't put sleeves in! Use the money you saved for better things.
Old Aug 5, 2014 | 05:57 AM
jonnyidfw's Avatar
jonnyidfw
Not sure if I had already out this in the post or not, but I already have the sleeves in my possession from when I was going to do an FI build.... But then I thought to myself, You already have 2 other Drag Racing cars, so I decided to do another Road Course car instead....
