Rough Idle - Possible fixes?
Old May 9, 2022 | 09:52 AM
フェアレディZ's Avatar
フェアレディZ
Default Rough Idle - Possible fixes?
Hey, I've noticed some rough idles lately. Usually if I'm waiting for a minute at a stop light, the car will vibrate or kick for just a second and the RPM will drop just a bit, then run normal, and then do it again a few seconds later. It's really weird. It wasn't too bad at first but it's seemed to become more frequent over time, however I never had any CEL.
Yesterday (Sunday), I was driving into work and my CEL started blinking and my engine was extremely rough, even while driving. I brought it home and I had Bank 3 Misfire code and random misfire code. I replaced all 6 spark plugs and had no more CEL and it's fine while driving, but the idle issues did not go away.
Anybody else experience something similar? Any possible solutions?
Thanks!
Also, as a side note, when I did my spark plugs I noticed my throttle body plate was pretty freaking dirty. Could this be related?
Old May 9, 2022 | 12:32 PM
travlee's Avatar
travlee
Master
Year and miles?
Old May 9, 2022 | 01:16 PM
フェアレディZ's Avatar
フェアレディZ
Originally Posted by travlee
Year and miles?
So sorry! 04, just flipped over to 92,000 today.
Old May 9, 2022 | 01:34 PM
travlee's Avatar
travlee
Master
Have you ever changed the camshaft sensors
Old May 9, 2022 | 01:38 PM
フェアレディZ's Avatar
フェアレディZ
I just bought the car about 3 weeks ago haha. Is that a common problem?
Old May 9, 2022 | 01:40 PM
フェアレディZ's Avatar
フェアレディZ
Removed the throttle body to clean it. Looks like it doesn't shut completely. Is it supposed to be like this? It's hard to see in pictures but it's not straight up and down inside the body, it looks like it's slanted maybe 15 degrees open. Should I be concerned?
Old May 9, 2022 | 02:12 PM
travlee's Avatar
travlee
Master
Very. Use oem, they don't like knock offs
Old May 10, 2022 | 03:26 AM
フェアレディZ's Avatar
フェアレディZ
So before buying anything, I removed my MAF and throttle body, and cleaned them both really good. Drove into work this morning and the issue is still there.
Old May 12, 2022 | 03:12 AM
フェアレディZ's Avatar
フェアレディZ
Figured it out! It was a bad coil pack.
Old May 12, 2022 | 04:03 AM
travlee's Avatar
travlee
Master
there ya go, glad you figured it out
QZU33N
Nov 28, 2021 12:52 PM
QZU33N
Nov 28, 2021 12:26 PM
Ryan Lemons
Dec 1, 2015 03:44 PM
Ryan Lemons
Nov 30, 2015 03:55 AM
eyeSea
Aug 1, 2013 08:18 PM
