Real HP numbers UNDER $300.00
Old Aug 31, 2006 | 06:34 AM
Ray123's Avatar
Ray123
Default Real HP numbers UNDER $300.00
The AAM Angled Plenum Spacer for the G35, 350Z & FX35 is the ultimate upgrade in the quest for more power. THIS IS OUR MOST POPULAR UPGRADE FOR THE VQ35DE - AND THE BIGGEST HORESPOWER GAIN FOR THE MONEY! The billet aluminum spacer sits between the factory upper and lower plenum, creating a larger volume to rush towards the cylinders. Power gains across the board. The upper RPM range opens up considerably. You get to keep your factory engine cover, your factory strut bar (350Z) and gain 10-15HP in under an hour.
Features of the AAM Spec Angled Plenum Spacer
Proprietary ANGLED Design Provides Additional Air Flow to the Front Cylinders
Retains Factory Strut Bar (350Z) and Engine Cover
Stock-like Appearance
Custom Cut In House on Our CNC Mill
Easy Install and Removal
Built with Strong and Lightweight 6061-T6 Aluminum
Package Contents
All Bolts Required for Securing the Plenum
Modified OEM Gasket to Reseal the Top Plenum
Spacers for the Strut Tower Brace
Detailed Directions
Recommended Install Time: 1 hour
Old Sep 11, 2006 | 10:44 PM
silver nismo's Avatar
silver nismo
It sounds good maybe i should get me 1, how much is it?
Old Sep 11, 2006 | 10:55 PM
kourosH's Avatar
kourosH
yea how much is it...does it go well with MD MREV2 + MD plenum spacer 5/16?
sales@czp
Sep 23, 2019 03:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
