2003 Nissan 350Z Dome light Not working
Old Feb 28, 2018 | 04:15 AM
Brandon Ritter's Avatar
Brandon Ritter
Default 2003 Nissan 350Z Dome light Not working
I recently purchased a 350Z and the dome light does not work. I checked the fuses they were good. And I pulled the bulbs and they both look good. It’s weird that both lights aren’t working. Any suggestions? I’m thinking I will replace the bulbs to see if that will fix it even though the ones in it look perfect.
Old Feb 28, 2018 | 04:29 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Don't buy bulbs just yet. Your BCM may just need to be reset. Disconnect your NEGATIVE battery terminal, then get back in the car and pump the brakes 10 to 15 times. Reconnect negative battery terminal. Done.. Hopefully that's all it needed. If not, think BCM.
Old Feb 28, 2018 | 11:36 AM
beezee's Avatar
beezee
The first thing to do is check if it is getting power. Put a volt meter on it. You need to pry the whole unit off the roof. Pretty easy.
rams
Mar 6, 2015 04:39 AM
avandss
28
Jun 3, 2013 07:20 PM
defragged1
Jan 29, 2013 12:24 PM
wish31
Sep 14, 2010 08:03 PM
