new owner of nismo1143 - track tires
hi this is my first post in this forum, i have been a proud owner of a honda S2000 the last few years. seen the nismo at the detroit auto show and decided it was going to be my next car.... i only had it a week so far and i do like it..........its so nice to have torque again. one thing i dont like about the car is the tire set up. i do participate in a few time attacks during the year, and i want to keep the rims on the car and not spend 2800 on a set of volks. so i will sacrifice a little time from my laps to keep my stock rims. i went to different rear tire size 285/35/19 the tire fits the rim soooo much better it 1/2 inch taller, 1inch wider and actually has a sidewall a hair bigger than the front. also i changed my tires to a michelin ps2..... anyone that tracks there z...... is there anything i should be aware or concerned with? also i look forward to meeting some of you and learning more about this car
Less rubber you have over the side of wheel, better road feel your going to have also less body roll as well.
It's reason why nissan had rays build 19x10 wheel and put only 265.35. in rear.
no staggered setup IMHO not useful on a FR car... have better bracking, less understeer and you can rotate the tires.
Matteo
I track my car and I just changed my tire setup to the Michelin ps2 too as of today, I'm hopeing to take her back out in a couple of months to compare. The stock setup was ok till my first track day. Let me know how you like the new tires.
Originally Posted by StoneZtech
Congrats, I'm number#1140. I think 265 is better.
Ataru pointed it out, but more tire will yield more grip. On the Z, a square setup, meaning the same tire size all around is preferred.
Wider tires dont' always make for better road feel.
On my old 08 Touring setup I had 225.45.18 front 245.45.18 in rear.
Back wheels always would bake lose on hard coners and VDC would kick in.
I have not had that problem with nismo setup.
Well other than the NISMO not having VDC, the wider footprint should help on those same corners.
Originally Posted by Carbon-Z
IT all depends on the tire and suspension setup, but wider will always have better grip. That also depends if you got a good tire for grip as well and not some cheap tires.
Most of the time very wide tires are simply for looks, but 275-285s are very functional for the power on the HR.
Wider than that however, there are diminishing returns and will likely be just for looks unless one is running FI.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
