Official Nismo Specs
I figured we can get an official Nismo Spec sheet going with all of the details
Sorry for reposting but I wanted to update the title so its more applicable.
If we can get this stickied, I would like everyone to add information as they come across it and post a link to the source
Copy and paste the information below and add in or edit to the specs you have found. I think in the long run this will save us from reposting the same spec questions over and over.
The first 8 are just some examples, please feel free to add in anything else.
1) front and rear camber
2) individual or final drive gearing ratios
FD 3.79
1th 3.79
2nd 2.32
3rd 1.62
4th 1.27
5th 1.00
6th 0.79
Rev 3.45
http://www.thecarconnection.com/spec...formance-specs
3) spring rates
Front 424 lbs
Rear 576 lbs
(Stock Z setup + 35% stiffer)
4) ground clearance
5) sway bar stiffness (are anti roll bars and sway bars the same thing?)
6) rebound and dampening rates
7) front and rear downforce lbs
8) curb weight (3353)
FD 3.79
1th 3.79
2nd 2.32
3rd 1.62
4th 1.27
5th 1.00
6th 0.79
Rev 3.45
3) spring rates
Front 424 lbs
Rear 576 lbs
4) ground clearance
