Spacers with Stock NISMO wheels?
Old Feb 3, 2010 | 11:03 PM
jerseystyle's Avatar
jerseystyle
Default Spacers with Stock NISMO wheels?
Anyone running spacers with their stock wheels? What width do you recommend? Are extended lugs necessary? I honestly don't know alot about them, but I am wanting to get a more aggressive stance. And ofcourse Pics would be great! Thanks!
Old Feb 3, 2010 | 11:22 PM
TheFarmer's Avatar
TheFarmer
I've seen a few members on here with 20-25mm spacers on their stock GT or Nismo wheels. I think it looks great!!
You don't need extended lugs if you buy spacers with new lugs already installed
Old Feb 3, 2010 | 11:28 PM
ITOzann's Avatar
ITOzann
^+1 or you can also get 25-30mm with built studs
Old Feb 4, 2010 | 12:25 AM
jerseystyle
Thanks for the help guys! Any recommended brands? Maybe Project Kics?
Old Feb 4, 2010 | 01:13 AM
TheFarmer's Avatar
TheFarmer
I've had great luck with CZP spacers from Concept Z Performance, check'em out in the vendor section wheel/tire section.
Old Feb 4, 2010 | 06:16 AM
diablox1's Avatar
diablox1
theres a ton of info on this on the forums.
that said, spacers are a pretty straightforward item, most of the top manufacturers quality is going to be similar. I've had excellent luck with both czp and ichiba.
Old Feb 4, 2010 | 06:24 AM
jerseystyle
Thanks again for the help guys. I posted on the sticky on the other wheel/tire forum. I just posted on here because there was nothing listed about the NISMO wheels. Looks like I am gonna go with 20mm up front and 25mm in the rear.
Old Feb 4, 2010 | 07:30 AM
Nismo 78's Avatar
Nismo 78
Yeah, I've seen a few guys on here with 20mm in front and 25mm in the rear. I'm not trying for the ultra aggressive look so I opted for 15mm & 20mm. I just ordered them, should have them by Saturday.
Old Feb 4, 2010 | 12:30 PM
NISMO462's Avatar
NISMO462
I would like to see some pics once a few of these are installed. With suspension, and tire specs...hopefully stock.
Old Feb 4, 2010 | 01:02 PM
NISM0_350z's Avatar
NISM0_350z
Any reason why you would run slightly wider spacers in the rear?
Old Feb 4, 2010 | 04:41 PM
ChuckW's Avatar
ChuckW
I do 25mm on all four corners. They look perfect.
Sorry no pics, snow rims/tires are on now.
Old Feb 4, 2010 | 05:28 PM
jerseystyle
Any rubbing issues with the NISMO wheels? Do the front's and rears look about even? Most on here go with 5mm wider on the rear so that's what I was going to opt with but I guess with the wide rear NISMO wheel, it shouldn't be necessary.
Old Feb 4, 2010 | 05:45 PM
ChuckW's Avatar
ChuckW
They look even. I could show you in March. The fronts would look too shallow without the 25mm.
No rubbing either.
Old Feb 4, 2010 | 05:52 PM
UpstateNismo's Avatar
UpstateNismo
What a coincidence,my friend was just telling me to do this today.i bet it would look awsome.
Old Feb 4, 2010 | 07:06 PM
jlvvega's Avatar
jlvvega
I have 15 mm at front and is great.
I tried the 15 mm on rears and they might rub I'm not taking chances.
Old Feb 4, 2010 | 08:29 PM
Nismo 78's Avatar
Nismo 78
I'm only getting my rear fenders rolled, also personal preference. I've seen what 25mm look like with oem nismo's and I want a slightly less aggressive look.
Old Feb 4, 2010 | 08:51 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Kingbaby to the rescue...
The Shaddix
I believe he's at 25 alla round
Stance GR+ PRO
[/QUOTE]
Old Feb 4, 2010 | 09:19 PM
KingBaby's Avatar
KingBaby
Hardest Setting
come to think of ut someone is also slammed with the stockers..screen name doesn't come to mind
Old Feb 4, 2010 | 09:54 PM
jerseystyle
Thanks KingBaby! That looks perfect. Gonna have to go 25mm all the way around now!
Old Feb 5, 2010 | 02:32 PM
Nismo1534's Avatar
Nismo1534
How wide of spacers can you apply without having rubbing/clearance issues with stock suspension on the Nismo?
