Brandon3434's 350z Nismo #0277
Old Jan 2, 2012 | 05:38 AM
  #341
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Originally Posted by brandon3434
With our transmissions/engines, things will always be a little different for each car. In my situation, my slave cylinder went out due to the clutch, then with the new hd slave cylinder, i had some play in my clutch due to lack of clutch fluid. With this wilwood master cylinder, it helps force the fluid in, which makes my clutch work correctly. Like I said, its different for each car, but if you have your tranny out doing the clutch, I would research the zspeed slave cylinder for sure. Joe has a thread open in the HR engine section about his slave cylinder, lots of info there...
Not so much you didn't have enough fluid, Just the fact that the stock masters wear out, get all gunked up and cause the pedal drop issue, Yours was pretty nasty inside also after I took it further apart.
This is after I cleaned some of the crap out to find the fluid hole. Imagine what one looks like with average mileage and not the low miles your car has...
Anyone that replaces the slave with our HD slave or a new stock slave should really consider replacing the master at the same time.
Also, the stock master cylinder design sucks and is why we are testing our new Wilwood set-up on your car
This is deep inside your master cylinder that was causing you issues.
Old Jan 2, 2012 | 05:44 AM
  #342
KingBaby's Avatar
KingBaby
Hardest Setting
Informative, thanks!
Old Jan 2, 2012 | 06:47 AM
  #343
jerseystyle's Avatar
jerseystyle
Great post but pic doesn't work.
EDIT: For those who can't see it.
Old Jan 17, 2012 | 10:23 AM
  #344
brandon3434's Avatar
brandon3434
OH, I just saw that post Joe, thanks for the info. Also, is that my master cylinder? Thanks again for all the help!
Old Jan 17, 2012 | 10:53 AM
  #345
Kcee91's Avatar
Kcee91
Hmmm. So I guess I'll be flushing out my fluid every 1 year or 10k miles. @Brandon, how's that Wilwood setup on your clutch? Interested.
Old Jan 17, 2012 | 10:55 AM
  #346
ZSpeedPerformance
Yes, That's after I cleaned it out to find the hole.....
Old Jan 17, 2012 | 11:32 AM
  #347
brandon3434
Ewwwwwwww, well good to know. The Wilwood master cylinder is working perfectly, so far. No problems what so ever...
Old Jan 17, 2012 | 11:37 AM
  #348
Kcee91's Avatar
Kcee91
So you just replaced the oem clutch fluid reservoir with the wilwood setup? Did you change the line distributing the fluid or just kept it stock? Thanks bro. Btw, sorry to thread jack, but can you possibly pm me on your stance coil over setup? That's my next to do before the new engine. hehehe! :thumb up: Hint hint.
Old Jan 17, 2012 | 11:42 AM
  #349
brandon3434
Yes, Joes setup comes with a SS line. And Kevin, click this----> https://my350z.com/forum/8941779-post28.html
Old Jan 17, 2012 | 05:05 PM
  #350
tkuntz's Avatar
tkuntz
how many miles have you guys racked up on your nismo's when this happens?
i have ran into an issue where i had no preasure on my pedal after down shifting on the highway or at high speeds, even up shifting at high speeds, so then i took it to nissan and they adjusted the clutch linkage and it works fine now.... but is this the end or should i expect some possible problems in the near future? i only have 13,000 miles on mine so far. if you could pm me that would be awesome....
sweet niz brandon, good work
Old Jan 17, 2012 | 06:00 PM
  #351
jerseystyle
I have over 60k and I just have some grinding down shifting from 6th to 5th.
Old Jan 17, 2012 | 06:08 PM
  #352
Kcee91's Avatar
Kcee91
Bad synchro...Still got warranty Jersey?
Old Jan 17, 2012 | 06:23 PM
  #353
jerseystyle
Yep, I have the top extended warranty. After my last car sh*t out on my right after the warranty, I swore to always buy the best extended they had!
Old Jan 17, 2012 | 06:43 PM
  #354
Kcee91's Avatar
Kcee91
Sorry to threadjack Brandon. lol Time for a fresh trans! Anyways good luck Jersey.
Old Jan 17, 2012 | 06:55 PM
  #355
KingBaby's Avatar
KingBaby
Hardest Setting
Just change fluids, don't think 60k is the end of a transmission!
Hopefully you guys get it all squared away!
Old Jan 17, 2012 | 07:58 PM
  #356
Kcee91's Avatar
Kcee91
@King, if he has a possible synchro issue, he should get that taken care of before the warranty ends. Just my two cents.
Old Jan 17, 2012 | 08:03 PM
  #357
KingBaby's Avatar
KingBaby
Hardest Setting
Oh, definitively getting warranty to cover it...
Old Jan 18, 2012 | 11:23 AM
  #358
Kcee91's Avatar
Kcee91
If not, just get your shifter realigned imo. It could also be the cause with a misalignment.
Old Jan 18, 2012 | 11:33 AM
  #359
jerseystyle
I did and nothing changed.
When I took it to Nissan, the head of the department took it out for a drive and said all is fine, but I had them change the fluids anyway. If it gets any worse I'll take it in again. I have the top extended warranty, so I'm not too worried about it.
Sorry again for jacking Brandon. I'm probably gonna go your route and upgrade everything. Ugh, so much to buy and so little money
Old Jan 18, 2012 | 02:34 PM
  #360
fhumphrey04's Avatar
fhumphrey04
Hey Brandon- what ever happened with the skid plate that was being made? Is it on your car?
If so- I want to see some pics
