Issues with factory NISMO sideskirts
Old Oct 17, 2011 | 01:14 PM
jerseystyle's Avatar
jerseystyle
Default Issues with factory NISMO sideskirts
So my skirts are getting a little loose and my one is starting to protrude a little at the top. Anyone else having this issue. I think when I get some time I'm gonna remove them and re attach them with some 3M or something to make them a little more snug. Any other suggestions?
Old Oct 17, 2011 | 02:47 PM
KingBaby's Avatar
KingBaby
Hardest Setting
On my passenger side near the door jam the sideskirt is coming loose from the factory 3m strip...
Old Oct 17, 2011 | 02:51 PM
JCITY's Avatar
JCITY
If they are getting loose...openings at the top,it would be best to take e'm off(a pain)and re-install.Did you originally put them on?Alot of guys that install skirts/lips etc. use the standard 3-M tape that you can buy at Home Depot etc.Its best to use tape especially made for panel installation.If applied per instructions,there should be no problems.3-M acrylic plus attachment tape is best.Auto body paint supply stores have it.
Also,its good to use 3-M adhesion promoter on surfaces before you attach the tape.
A heat gun or hairdryer is good to use to heat the surfaces(that have been cleaned well with alcohol)before installtion.Removing the skirts is a job.Especially cleaning the old gunk off the surfaces.This will take the most time...
Old Oct 17, 2011 | 02:54 PM
jerseystyle
Sounds like fun. Any specific places to buy the tape?
Old Oct 17, 2011 | 03:01 PM
bmccann101's Avatar
bmccann101
nah, as long as its the 3m grey tape, its fine. Adhesion promoter is key. and make sure yo intall it with very clean hands, clean car, and inside where its warm. dont do it outside in the parking lot.. i was just in MO, its frikin cold there already .
When youre absolutley sure its ready to roll, peel the tape back and hit it all with a heat gun.. dont melt it, but still, get it hot.. helps the part thats already stuck to the one side adhere, and sets up the side your about to stick on adhere too.
I give the whole area a gentle go over w a heat gun when im done too.
Ive never done that skirt, but the carbon license plate frames are a total *****.. if you dont tape it super well, they dont sit flush and look like *** after its been outside in the heat a few times.
Old Oct 17, 2011 | 03:10 PM
saywat?'s Avatar
saywat?
i always thought oem body add ons never install using double sided tape.
Old Oct 17, 2011 | 03:13 PM
jerseystyle
I guess I'll find out when I start tearing it apart. Sounds like an all day project. Gonna have to put it off a few weeks due to work.
Old Oct 17, 2011 | 03:15 PM
saywat?'s Avatar
saywat?
^yea ive only seen oem body addons bolt up and snap into the car. but i could be wrong cus i dont have a nismo
Old Oct 17, 2011 | 03:57 PM
JCITY's Avatar
JCITY
Thumbs up
The 3-M part # is
06382 for the tape.Auto body supply stores have along with the adhesion promoter.You can also order online.The tape comes in several size roles.Usually 1/4" wide .Its black.
There is a 3-M all purpose cleaner that is available for removal of the old
tape residue.Comes in pint cans.As mentioned before and by others,heat the tape&surfaces to promote a good adhesion.I use 91% rubbing alcohol to clean surfaces after you get all the residue off.
Old Oct 17, 2011 | 04:00 PM
Waiz's Avatar
Waiz
Sounds like they are crap, just send them to me instead
Jersey, are you hitting things and they are loosening or is it just a gentle sag over time?
Old Oct 17, 2011 | 04:03 PM
JCITY's Avatar
JCITY
Thumbs up
You are right about the heat.Thats a key point.Lately I've done some CF work using 5mm material with pre applied high performance sheet backing.
This stuff(3-m) is great.Its good for hi temp applications...300 degrees.
But,you gotta heat it first.Heat again when applied and use a roller.Its on for good.
Old Oct 17, 2011 | 04:09 PM
jerseystyle
Ha Ha! Well, I currently live on a gravel road (and have for the last year) so I'm sure that has a lot to do with it. My front clear markers are also loose! Thank god I'm moving to a real street/neighborhood this weekend. I appreciate all the help guys. It might be a few weeks before I do this but I'll keep everyone posted. Anyone recommend a website to buy the 3G stuff from? Remember, I'm currently in bum-***-Missouri!
Old Oct 17, 2011 | 04:11 PM
jerseystyle
Fugging autocorrect! I meant 3M!
Old Oct 17, 2011 | 07:15 PM
nismofreak1208's Avatar
nismofreak1208
^lol, i hate autocorrect to
Old Oct 17, 2011 | 10:03 PM
370zforme's Avatar
370zforme
mine is cracking at the top...... Nissan quoted me $500 for one side skirt.
Old Oct 17, 2011 | 10:10 PM
Waiz's Avatar
Waiz
Here's the 3G that I used for my rear pieces:
http://www.amazon.com/3M-Molding-Tap...8918150&sr=8-6
Old Oct 17, 2011 | 10:34 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Old Oct 18, 2011 | 09:46 AM
jerseystyle
Love you guys!
Old Oct 18, 2011 | 10:21 AM
Alloy_475's Avatar
Alloy_475
Body parts will always be expensive...and someday will disappear due to the Nismo being a limited production car....although you can't tell they're limited production by what some on these forums do to them.
Old Oct 19, 2011 | 10:34 AM
TehkMob's Avatar
TehkMob
Hey can we get pics of the sag or whatever.. You really shouldn't need 3m.. You might need a couple new clips tbh. Pics of said sag and problem should be a easy fix.
