nismo bumper tuck?
Old Jan 5, 2013 | 02:15 PM
Bumble Z's Avatar
Bumble Z
Default nismo bumper tuck?
I seen the bumper tuck on one of the nismos with the hks setup in the nismo exhaust thread looked in the bumper tuck section thread no luck.. Anyone know how to do this? Im thinking it should be the same concept as the regular bumper tuck on a non nismo z. If anyone can shed some light it be greatly appreciated.
Old Jan 5, 2013 | 05:06 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Don't know how that would be achieved?
Only unless that owner removed the rear diffuser to allow more of the exhaust to be seen....other than that you may be imagining things or thinking of the exotic speed exhaust which looks to hang lower on our rear....
All I got
Old Jan 5, 2013 | 07:58 PM
FlipCpt45's Avatar
FlipCpt45
Make a DIY!
I need to do mine since the JIC 3in Ti sits a bit close.. It hasn't melted yet, but it has a few scuffs where the exhaust rubbed on it (before I adjusted it not to be on it).
Old Jan 5, 2013 | 08:53 PM
pro_350z's Avatar
pro_350z
pics of other nismo?
Old Jan 6, 2013 | 03:29 AM
Bumble Z's Avatar
Bumble Z
That nismo is on the nismo after market exhaust sticky its not a nismo but its a nismo oem rear bumper its the one with the hks labled bumper tuck next to it and the license plate drift z ill try and post a pic later im on through my phone right now
Old Jan 6, 2013 | 01:50 PM
Bumble Z's Avatar
Bumble Z
http://i359.photobucket.com/albums/o...s/HKS_TUCK.jpg its titled on the page bumper tuck
Old Jan 6, 2013 | 01:58 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Ok from looking at that picture two things could of been done! One remove the rear diffuser, or two he pushed up on the diffuser causing it to bend the two support brackets causing it to sit higher!
Old Jan 6, 2013 | 02:04 PM
Bumble Z's Avatar
Bumble Z
judging by the pic i dont think he removed it because you can still see the 2 bumps on it just sitting higher
Old Jan 7, 2013 | 09:53 AM
jerseystyle's Avatar
jerseystyle
Why would this be needed? It doesn't look much different then stock and I think you'd only be able to see it when laying on the ground
Old Jan 7, 2013 | 05:29 PM
Trance4c's Avatar
Trance4c
I ask myself that a lot when viewing threads
Old Jan 7, 2013 | 10:32 PM
Bumble Z's Avatar
Bumble Z
For looks mainly id like to show off the resonators on the exhaust
Old Jan 8, 2013 | 08:02 AM
musubi's Avatar
musubi
From the looks of the picture, I can't tell if it's tucked or not. When I installed my Nismo S-Tune, the exhaust canister touched and flushed right up against the black plastic portion of the rear bumper. I almost thought I had to cut a portion of it out. When I was under there, it was hard to imagine bending anything further up. Hopefully you're able to accomplish what you want. Keep us posted.
Old Jan 8, 2013 | 11:42 AM
jerseystyle
You would literally need to be laying on the ground to see them
Old Jan 8, 2013 | 01:28 PM
Bumble Z's Avatar
Bumble Z
Another reason is the resonators are pushing on the defuser n it has a buldge on the left side
Old Mar 28, 2013 | 05:25 PM
Kyoso_Joey's Avatar
Kyoso_Joey
Bump! I want to know how to do this. I just got a Tanabe Medallion exhaust on and that plastic peice looks like its sagging a bit. I think it would look a lot better if it wasn't there.
Old Apr 15, 2013 | 08:50 PM
Kyoso_Joey's Avatar
Kyoso_Joey
Anybody?
Old Apr 19, 2013 | 04:22 AM
KingBaby's Avatar
KingBaby
Hardest Setting
+1
Anybody?
Walk to the back of your nismo and inspect it yourself...then get done and look underneath for those two brackets...then as mention above in my previous post...you will wanna push them up. As if you where doing a bicep curl?
Justin100
Nov 25, 2021 06:26 AM
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
