Zspeed under shroud question for the Nismo V3 bumper
Old Aug 10, 2014 | 02:52 PM
Nismo530's Avatar
Nismo530
Default Zspeed under shroud question for the Nismo V3 bumper
Is it absolutely necessary to buy the extension piece they sell for the under shroud? I haven't crawled under the car yet to see if it fits without it.
Old Aug 10, 2014 | 03:21 PM
Italianjoe1's Avatar
Italianjoe1
Do you have a Nismo? The factory nismo has a plastic piece there that connects to the normal shroud. If you are adding the nismo bumper to a non-nismo car you would need either the factory plastic panel or the Z speed extension panel.
Old Aug 10, 2014 | 09:02 PM
Nismo530's Avatar
Nismo530
Sweet the answer I was looking for. Yes I have a Nismo Z, so the v3 diffuser does hook up to the regular shroud. Perfect.
Old Aug 11, 2014 | 03:55 PM
Italianjoe1
There ya go. I started with just the undershroud on mine, and ended up swapping my factory plastic for the aluminum extension piece.
Old Oct 30, 2014 | 06:35 PM
EvilCrayon's Avatar
EvilCrayon
It does not come with instructions and I ended up reusing bolts. Try not to use longer bolts towards the thinner part of the lip as you risk screws going protruding through the top of your lip.
My stock plastic engine guard was always pretty awful but I did feel a measurable difference, especially on the front straight of a track or at high speed but that's just measured by my *** so yeah I'm probably just talking out my ***.
Oil changes are easier too.
Old Nov 4, 2014 | 09:23 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Originally Posted by evilcrayon
try not to use longer bolts towards the thinner part of the lip as you risk screws going protruding through the top of your lip.
+1000
Old Nov 7, 2014 | 04:22 AM
trustr888's Avatar
trustr888
Originally Posted by KingBaby
+1000
YES!!!! That is what happened to a buddy of mines V3 bumper as well. It spider cracks the paint if it goes too far.
issyz
Jul 2, 2017 03:04 PM
bcoffee20
Nov 19, 2015 06:39 PM
davidm350
Oct 31, 2015 02:28 PM
sherm
Sep 10, 2015 11:02 PM
