Nitrous Oxide Too soon, jr.
Nitrous install questions
Old Feb 23, 2003 | 07:15 AM
02trex's Avatar
02trex
Default Nitrous install questions
For those of you with nitrous installed, at what location did you tap the fuel line? Also, as I have the Zex kit, I need to know the color of the voltage output wire for the TPS.
Thanks in advance.
Old Feb 23, 2003 | 05:57 PM
2003z33's Avatar
2003z33
Default Re: Nitrous install questions
Thanks in advance.
Old Feb 25, 2003 | 01:00 PM
02trex's Avatar
02trex
Thanks for the pic. How did you cut the line? Is it simply hard rubber? Mine feels as though it is inner-lined with some sort of hard tubing.
Also, what about the color of the TPS voltage output wire?
I appreciate any further help you can provide.
Old Feb 25, 2003 | 05:13 PM
McDan's Avatar
McDan
I would also like to know the answers to those questions...
Dan
Old Feb 25, 2003 | 05:50 PM
2003z33's Avatar
2003z33
The Fuel hose is a Heat shrunk Hose which can be cut with a blade. Be careful..It may be presurized..As for the TPS wire, you may need to talk to MAX HAX who has a ZEX kit installed..I have NOS kit and use the switch at my gas pedal and not the TPS..
Mike
Old Feb 25, 2003 | 05:51 PM
2003z33's Avatar
2003z33
Workshop12
Mar 23, 2020 01:45 PM
TrackFiddy
Sep 24, 2015 11:40 PM
Suffolk350z
Sep 13, 2015 02:43 PM
