Q: interior of plenum for N2O.
before doing my N2O install, I had bought an OE plenum (upper/lower) with the intent to modify the interior of it for NA (something simlar to MD's [motordyne] modifications, but more extensive)...but now that I have nitrous, I've been searching to find what the best plenum design would be.
I've tried looking at intake manifold/plenums for carburetors, since those are also designed for air/fuel mixtures to flow through them, but I haven't found too much info as of yet.
preliminary design thoughts:
-perform similar modifications to the lower plenum as MD (reduce material over front runners)
-leave interior surface untouched (a rougher surface helps to evaporate any liquid that is on it...)
-should I reduce the runner lenghts? (this would likely move the peak power higher in the rpm range...)
-any other thoughts???
goal: maximize power for N2O use in higher RPM range (4.5K and above) while retaining streetability (I still need to drive this car daily)
thanks,
Peter
**I know that I could just increase my N2O shot, but for now, I'm staying at a 75 shot and just want to maximize what I have.
thanks,
Peter
thanks,
Peter
thanks,
Peter
Maybe smoothing out the rough passageways might help a bit but I don't think you will see big gains. Just install the 100 shot jets and turn that frown upside down.
Tochigi_236
Sep 27, 2015 03:40 PM
