Nitrous Oxide Too soon, jr.
i could only use a wet kit??
Old Nov 7, 2006 | 06:16 PM
g35kid18's Avatar
g35kid18
Default i could only use a wet kit??
i was reading in the sticky above that the fuel regulator is in the trunk so there is no way to use a dry kit on our car?? and is all nitrous kits universal?? my friend had a nx kit in his interga can i use it?
Old Nov 7, 2006 | 06:39 PM
g35kid18's Avatar
g35kid18
sorry guys i found my answer about the dry kit everyone is against it but can i use a nx wet kit off an interga?
Old Nov 7, 2006 | 07:49 PM
dTor's Avatar
dTor
Yes.
Old Nov 7, 2006 | 07:52 PM
dTor's Avatar
dTor
Nitrous kits are pretty much universal, assuming you're using a basic nozzle setup, as opposed to a plate attached between the throttle body and plenum or something similar. You should read the FAQ and get as much info as you can before you hook up anything.
I've had my nitrous stuff in a box for almost a month now just to make sure I know everything there is to know about it before I install it.
Old Nov 8, 2006 | 03:38 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
yup, they are all pretty much the same when you are talking about little shots (under 150)
after that you have to start using -6AN lines and direct porting it to make sure it works well.
but yes a wet kit off an integra will work just fine.
let me know if you need to find a place for any other parts for you kit...
Old Nov 8, 2006 | 11:18 PM
g35kid18's Avatar
g35kid18
sorry for all the question but i have one more do i need to replace my fuel pump and my fuel filter if im only going to run a 100 to a 125 shot.. just something that dsport magazine said u should do
Old Nov 8, 2006 | 11:20 PM
michaeljr6's Avatar
michaeljr6
yes replace fuel pump
EnjukuRacing
Sep 30, 2015 06:55 AM
