Pods and gauges
I will be buying a u-tek very soon and running 100 shot of nitrous after the tune. need to know what kind of gauges will i need. I will be getting AEM's wideband as one of my gauges (one of three) what else will i need. I already have a pressure gauge on the bottle so i would not be needing one. Thanks for ur input need asap.
Originally Posted by coachk
Where are you putting the bottle? The reason I ask this is because you should have a N20 pressure gauge somewhere visible while your driving in case you spray you can see if the bottle pressure is where it should be.Also get a DynoTune activation switch
the bottle is in the trunk. not too worried about the pressure since i always check before i run.
bcoffee20
Nov 19, 2015 06:39 PM
