Nitrous Oxide Too soon, jr.
Leak!! Help
Old Jul 18, 2008 | 11:53 AM
2boosted4u's Avatar
2boosted4u
Default Leak!! Help
i hooked up 75% of my system and tested out how everything holds pressure and the auto off solinoid for the blanket is leaking from the screw inbetween the wire leads...does it need electricity to hold pressure?? i tried adjusting the screw to try and stop it and its not workingl...any ideas?? thanks in advanced!
Old Jul 18, 2008 | 09:13 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
What are you talking about? Please, write in comprehensible, coherent sentences.
Old Jul 22, 2008 | 08:00 AM
2boosted4u's Avatar
2boosted4u
on the dyno tune auto off solinoid for the blanket, at the top where wires plug in, its the bolt between the wire leads...
Old Jul 22, 2008 | 08:54 AM
silver350tn's Avatar
silver350tn
what are you talking about? slow down
Old Jul 22, 2008 | 09:17 AM
one350zfan's Avatar
one350zfan
Call dynotune because it shouldn't leak.
That screw is for adjusting the PSI telling the blanket when to turn on
Old Jul 22, 2008 | 10:11 AM
3hree5ive0ero
Retired Admin
Actually, the screw is what turns OFF the blanket (once it reaches a predetermined psi).
I still have no idea what the hell you're talking about. There's no solenoid there, nor anything really to leak.
I don't understand how that part is leaking. As the above guy said, call DynoTune and talk to them about it. They should get it straightened out for you. As far as I'm concerned (if everything you said is correct), you have a defective item.
Old Jul 22, 2008 | 04:41 PM
2boosted4u's Avatar
2boosted4u
i guess its not a solinoid....its the thing that turns off the blanket at a certain psi...i would call but by the time i get home from work there closed...figures right. well everthing else is done and im sprayn a 100 shot....feels awsome but of course...i wanna go fasster now and i need to get the blanket workn..thanks for the help
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
