Nitrous Oxide Too soon, jr.
From a NX 75 shot to a 150 shot!
Old Feb 13, 2012 | 12:02 PM
dorrifto's Avatar
dorrifto
So I want you opinion. I have been debating on if i want a 150 shot or 200(+) shot. Traction would be my enemy here. remember, I am in the lighter weight s14. I have a VLSD from the j30, and stock axles. Will be investing in drag radials, not slicks. So here are my thoughts: If I use a 200 shot, what if I cant get traction in second gear and have to wait until third to spray? would it be better to drop to a 150 shot so that I can spray through one extra gear? or do you think I shouldnt have problems sticking with the 200?
Is there something else I am over looking?
Old Feb 13, 2012 | 02:41 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
There's lots you're overlooking. Sift through the nitrous forums here and elsewhere to see what other options are available for you. Start with progressive controllers and 2-stage set ups.
Old Feb 13, 2012 | 03:10 PM
dorrifto's Avatar
dorrifto
I have actually considered both of those options, but decided they were out of budget before this March (when I am racing my car).
and after the past few months of crawling all over this nitrous forums. I have not found anyone running over 150 shot, and not to mention, I am the only one in an S-chassis so that throws a very large variable that the z cars differ.
just looking for opinions from those of you who are more experienced than I.
Old Feb 13, 2012 | 03:38 PM
3hree5ive0ero
Retired Admin
There's 2 or 3 members that have run over 150 shot here but none of them are still frequent visitors of the site, unfortunately.
150 shot all at once will put a tremendous amount of strain on your engine, so increasing it further probably wouldn't be a good idea unless you build your engine to hold up to the power/torque increase. Progressive controllers and multi-stages can help but you'll still be limited by the engine in the end.
Also, the fact that you've a S14 doesn't change anything related to nitrous if you're still using a regular rev-up from a Z. The only thing it changes is your driveability on the spray due to lighter weight.
Old Feb 13, 2012 | 05:21 PM
dorrifto's Avatar
dorrifto
the engine is currently being built to handle 600hp. its sleeved, has h beam rods, and wiseco pistons.
Old Feb 13, 2012 | 05:58 PM
3hree5ive0ero
Retired Admin
Oh, rofl. My mistake. 150 shot should be nothing. Still, you will fight for traction, like you said, and I'd say a progressive controller will be your best bet. They're not expensive either.
Old Feb 13, 2012 | 08:01 PM
dorrifto's Avatar
dorrifto
I will look into it. I like fjo's progressive controller. It was a window switch and a throttle switch all built it. then I could sell my Zex window switch to make some money back lol
So for the race in March, I will just keep it at 150 shot. Thanks!
Old Feb 13, 2012 | 09:00 PM
CLyons0203's Avatar
CLyons0203
have u ever sprayed nitrous? 150shot is alot! I started out with a 75shot and barely had traction using 275/30/20 street tires. Went up to a 105 shot and traction was nil in first gear. I am auto by the way.
I would suggest doing a dual stage shot. two shots of 75. Spraying nitrous thru all gears with traction is what u want. The 75 shot in first gear would hook sometimes and when it did, the car shot out the hole.
Old Feb 13, 2012 | 09:53 PM
ajcool2's Avatar
ajcool2
I've run 125 shot on 275/35/19 street tires and stock street tires at the track and pulled 1.8 60's spraying at the top of 1st. It was hooking pretty good and I probably could have sprayed a little sooner. On slicks I pull 1.6's.
Old Feb 15, 2012 | 01:34 PM
mgrotel's Avatar
mgrotel
i would stick to the 150 shot because anything more and you might get pooling, which is bad for any motor, built or not. there is a reason that 150 kinda seems to be the limit around here. if you must go above 150, i would not only suggest a progressive shot like others, but also look into a dry shot instead, to get around the pooling danger.
Old Feb 15, 2012 | 08:03 PM
3hree5ive0ero
Retired Admin
With a dry shot, how's he going to get the extra fuel that's needed?
People go with a direct port set up when they do big shots.
Old Feb 16, 2012 | 05:50 AM
mgrotel's Avatar
mgrotel
i meant direct port when i said dry shot, my bad. either way, 200 is too much for a single fogger
Old Feb 16, 2012 | 03:08 PM
3hree5ive0ero
Retired Admin
^ I agree, but OP is trying to cut corners wherever possible to save money.
Old Feb 16, 2012 | 04:06 PM
dorrifto's Avatar
dorrifto
to an extent lol. I will be able to get a progressive controller after I get caught up on bills. this recent project has set me back. I just wanted to know what I can get away with for the race coming up in March. but yeah, i will just stay with the 150 shot until later.
Old Feb 21, 2012 | 01:49 PM
mgrotel's Avatar
mgrotel
are you planning on keeping the stock fuel pump for the 150 wet shot?
Old Feb 21, 2012 | 08:05 PM
dorrifto's Avatar
dorrifto
Never had the stock fuel pump. I upgraded to a 255 before I even did the vq swap
Old Mar 13, 2012 | 11:40 PM
dorrifto's Avatar
dorrifto
FINALLY got some work done on the car. life can be distracting sometimes.
Bought some mil-spec plugs from Jordan Innovations to make wiring through the firewall a little cleaner and less painful.
marked all wires
Begin soldering
aaand done
DIY wiring tuck, EASY MODE
Ran it all under the intake mani. I doubled up all my extra long wires down here too to keep them out of the way
I dont know how hot it would get so I wrapped it in heat wrap.
picked up an oil catch can today
Going to work on it more tomorrow. Hope to have it done by this weekend.
Old Mar 14, 2012 | 11:55 AM
  #38
3hree5ive0ero
Retired Admin
That looks clean. I'd love to do the wire-tuck myself but I'm afraid of something messing up (or eventually) and consequently having to undo everything then redo everything all over.
Old Mar 16, 2012 | 12:09 AM
  #39
dorrifto's Avatar
dorrifto
ha just start soldering some spare wires for awhile. I used to be afraid of wiring until I began to solder. then i lost the fear because I knew i could fix whatever i messed up. since then I have just gotten better and more confident at doing anything with my wiring harness.
Old Mar 16, 2012 | 12:16 AM
  #40
dorrifto's Avatar
dorrifto
So I got the engine in there today. I started this morning by installing my LW flywheel and stage 4 Comp Clutch.
then dropped the motor in.
took my wire tuck a little further and I am running any wires destined for the fuse box through the fender well.
When I soldered my milspec harness connectors, I had a few spots left open. So I put random (yet color coded) wires on those spots so that I can run any sort of future sensor or whatever through the milspec plugs without having to take it apart. in this pic, you can see a bunch of them poking up by the fuse box, and below is me delegating those extra wires under the floor board.
I have a lot more wiring left to do tomorrow, then just hook everything else up and should be able to fire it up!
