Nitrous Oxide Too soon, jr.
Attn: MSD Widow Switch users
Old Mar 1, 2004 | 09:02 AM
lanzzor's Avatar
lanzzor
I just used a normal relay. I think MSD is just trying to sell us a "special relay".
Old Mar 1, 2004 | 10:01 AM
webcarconnection's Avatar
webcarconnection
Normal relay will work fine!!!
Old Mar 1, 2004 | 05:36 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Alright cool, good to know.
Old Mar 11, 2004 | 09:58 AM
McDan's Avatar
McDan
Default Re: Attn: MSD Widow Switch users
Originally posted by ZU L8R
I just off the phone with Ruben about sending my unit in. He said that he could modify the unit but doesn't know if it will work or not. He said nobody ever let him know if the modifications they made worked. I have #8956 my understanding is they just need to modify the voltage and it will work. Can anyone confirm this? Thanks!
They (MSD) are so full of ****. I replied and told them several times after getting mine up and running a year ago. I did almost all the footwork explaining how it would work and providing information for them. They must not communicate internally worth a ****.
Dan
Old Mar 11, 2004 | 01:04 PM
12SecZ's Avatar
12SecZ
I was hoping you would show up. I remember all the BS you went through with ZEX too as did I.
Old Mar 13, 2004 | 05:16 PM
was wesman's Avatar
was wesman
So if you're using the MSD window switch, there's no need for a WOT switch correct ?
--wes
Old Mar 13, 2004 | 06:26 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
--wes
No, you still need a WOT so you won't spray @ half throttle. You could be @ 4k rpm's and not be @ full throttle. Your window switch would be open but ithe WOT will keep it from spraying until you step on it
Old Mar 13, 2004 | 06:35 PM
was wesman's Avatar
was wesman
That makes sense
What kit do you have ? If it's NOS, do you know the part # on the kit ?
--wes
Old Mar 13, 2004 | 06:54 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
That makes sense
--wes
I have a Nitrous Express kit, part 20923. The kit is sitting in my room and I'm waiting on MSD to send my window switch back to me.
Old Mar 14, 2004 | 04:21 AM
titankiller's Avatar
titankiller
Old Mar 14, 2004 | 04:23 AM
titankiller
Will the #8969 digital window switch work without modifications.
Old Mar 17, 2004 | 10:59 PM
belerin's Avatar
belerin
yep, that is what I am using and it works great.
Old Mar 22, 2004 | 04:37 AM
lanzzor's Avatar
lanzzor
The saga continues,,,I talked with Rubin at MSD and was told that both versions would need to be modified. Sent my DAS unit in and got it back Friday,Still does not work. I don't think they did anything to this unit but just put it in a box and sent it back to me. On the back of the unit, it does not look like the case was opened, you can tell the original double sided tap is still in place. Unless they can flash these things through the rmp module port, it looks like they did nothing
Old Mar 23, 2004 | 10:15 AM
lanzzor's Avatar
lanzzor
...Rubin now says(3/23/04) that 8956-1 is just a modified 8956...He said that the -1 unit will work out of the box on these cars and that they just "calibrated" my unit but it still does not work, Damnit...Did anyone talk with someone about the "Help Desk" techs about this issues...
350Z_Al
Oct 29, 2020 07:44 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
