Dynotune/NOS nitrous kit
Copied from the public forums: https://my350z.com/forum/turbos-nitr...ml#post9294254
Price: $495 + shipping
Up for sale is a slightly used Nitrous *wet*(fuel and nitrous) system that I had in my 2006 350z with a few extras. I opted to get a kit without the bottle though because I preferred the look of the NOS bottle. Everything worked as of the time I removed the system (two months ago); I am just selling because I cant use it for Autocross events and its just been sitting in my room. The white stuff you may see on the threads is plumbing sealant.
I will be listing this on ebay a week after it posts on the forums; I want it gone. Just giving you guys first chance at it.
Parts included in this sale:
NOS 10lb bottle
Zex nitrous quick connect bottle brackets (the best brackets I could find, really easy to remove the bottle with these).
2 x 16ft 4an braided stainless steel line (blue ends), 1 is completely new.
Dynotune nitrous solenoid
Dynotune fuel solenoid
2 x 2ft 3an braided stainless steel lines (one blue, one red)
2ft 4an braided stainless steel line (red)
4ft 4an braided stainless steel line (red)
.030 and .054 jets (about 125 shot)
Dynotune high flow wet nozzle, black
Wet nozzle mounting adaptor (to mount it to your intake)
3 switches (black with blue led) and one button
NOS nitrous controller 2 stage WOT/RPM activated window switch (http://www.holley.com/15982NOS.asp)
Dynotune fuel rail adaptor so you can install the kit without cutting fuel lines (2 bolts and it comes right out)
NOS nitrous solenoid (I used it for purge)
Purge line with fitting and mounts
Dynotune liquid filled nitrous pressure gauge
New (unopened) o-rings for the fuel rail adaptor.
5 relays
3 fuses
A bunch of wiring
A bunch of connectors.
Base Dynotune 03-06 350z/g35 kit - $379.00
NOS purge kit - $125.95
NOS nitrous bottle - $209.95
Zex nitrous bottle brackets - $16.25
NOS window switch - $155.99
Pressure gauge - $24.95
Automatic bottle warmer - $119.00
4AN 16ft line - $89.62
Switches - $25
Relays - $20
As you can see, I have about $1150 invested in this kit plus miscellaneous costs, so the price of $495 is a steal; this wont last long!
As a side note -> If I manage to find the other 10 jets that I have before this sells I will throw those in as well, but as of now I cant find them.
Just a little info -> Nitrous is no more dangerous to your engine than a turbo or supercharger. It earns its bad name from people hooking up a 150 shot to their engine that puts out 140hp without a tune and then blowing the engine and blaming it on the nitrous rather than taking credit for doing something wrong. The typical recommended *maximum* shot without rebuilding your internals is less than 50% of your stock horsepower.
This kit is sold as-is with no warranties, expressed or implied.
NOS 10lb bottle
5 relays
3 fuses
A bunch of wiring
Switches - $25
Relays - $20
