Help: Tires rubbing in fender
Old Jan 31, 2012 | 08:43 AM
Esoj's Avatar
Esoj
Question Help: Tires rubbing in fender
Hi all!
I just want to ask for help since I tried to search and everything that I read says the opposite of what I'm experiencing. I have an 03' Z with 63,000 miles on it. Last October I decided to invest on wheels and tires and I bought WEDSSPORT SA55M 19X10.5 +15 (rear), 19X9.5 +15 (Front). I have it on stock height still and have 245/35/19 (front) and 275/35/19 (rears) tires.
The issue is that when I drive it at around 35-70mph and the road suddenly has dips (not potholes) either side of the rear tires (mostly rear left) and sometimes the front tires (mostly front left) scrape, weird thing is it only scrapes one tire at a time. I had my alignment already twice since October with 2 different Firestone locations here in Lynnwood/Everett area sine I got the lifetime alignment with them and the first alignment was really bad and after that it lessen the scraping but this time when I go at around 60+ mph and there are dips again I scrape same scenario so I brought it back for an alignment and they told me everything was into oem spec.
I tried to research on this since scraping is really not a good thing but everyone says that if you are on stock height (stock springs and all that) I shouldn't be expecting any scraping.
Sorry for the long read here but I hope this explains my issue and any suggestions would be great.
Old Jan 31, 2012 | 08:50 AM
seymore4's Avatar
seymore4
Professional
First thing I would do is look inside the fenderwell and see if you can identify exactly where its rubbing and go from there. For the rear most likely the problem can be solved by rolling the fenders, the front not so much. If its rubbing on the plastic liner try trimming it or removing it all together, if you don't mind spending some money invest in a quality set of coilovers to stiffen up the suspension.
Old Jan 31, 2012 | 10:08 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Your offsets are pretty low, but on stock height it shouldn't be hard to get it to stop rubbing.
What your experiencing is completely normal for wheels of that size/offset, though. It's a clearance issue, not an alignment issue. You can tweak the alignment to help the problem, but you're gonna have to trim your fender liners.
Get under the car and see if you can tell where it's rubbing. You should be able to see pretty easily.
Old Jan 31, 2012 | 04:42 PM
Czarrr's Avatar
Czarrr
Roll the rears. +15 is cutting it pretty close.
As for the front, remove the top most fender liner bolt. You should be set.
Old Feb 1, 2012 | 01:52 PM
Esoj's Avatar
Esoj
Thanks for the replies. I would remove the wheels this weekend and I'll see where it really rubsand I will update this again. Thanks for all the inputs.
Justin100
Nov 25, 2021 06:26 AM
