CA smog-legal mods besides Pop Charger?
Old Oct 10, 2006 | 09:52 AM
mg350ZR's Avatar
mg350ZR
Question CA smog-legal mods besides Pop Charger?
Which engine (intake/exhaust) modifications will pass smog in CA?
It is my understanding that the Z should be able to pass smog inspection in CA with the pop charger installed (is this correct?). It is also obvious that turbos, supercharging, and headers will not pass smog.
What about some of the other common mods (Motordyne 5/16 spacer, MREV, exhaust, etc.)? Will these or any other intake/exhaust modifications pass smog check in CA?
Thanks.
Old Oct 10, 2006 | 11:48 AM
zwindsor's Avatar
zwindsor
Twisty addict
Catback exhaust will. I've got the Motordyne 1/4" spacer and I passed smog (had it checked just for kicks to see if it would pass and also to see if the techs would notice anything).
Old Oct 10, 2006 | 11:49 AM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
This also needs a sticky.
Motordyne spacer isn't legal but undetectable.
Old Oct 10, 2006 | 12:25 PM
THE TECH's Avatar
THE TECH
Vortech or Stillen S/C.
Most DC headers are 50 state legal.
Old Oct 11, 2006 | 07:12 AM
kaybee650's Avatar
kaybee650
injen intake but the only gains shown is from the short ram.... carb legal..
Old Oct 12, 2006 | 12:48 AM
nofeardude87's Avatar
nofeardude87
only the older model injen intakes are CARB legal...forgot the model # something like 1985
Old Oct 16, 2006 | 10:03 AM
mg350ZR's Avatar
mg350ZR
Originally Posted by zwindsor
... I've got the Motordyne 1/4" spacer and I passed smog (had it checked just for kicks to see if it would pass and also to see if the techs would notice anything).
Based on this info I am guessing that the smog emissions reading with the Motordyne spacer (and Pop Charger) installed will not be any different than without it, and the only way that the car may not pass the smog will be based on the visual inspection by the tech who may or may not notice the spacer. Is this correct?
Old Oct 16, 2006 | 05:49 PM
o snap its eric's Avatar
o snap its eric
everything is smog legal up to the point where you put on turbo(s) or test pipe in ca.
visual is another topic
Old Oct 16, 2006 | 07:25 PM
zwindsor's Avatar
zwindsor
Twisty addict
That is correct.
Old Nov 10, 2006 | 02:33 PM
Stanky19's Avatar
Stanky19
but i know that stillen and nismo cat backs will pass visual as well due to the carb legal # that they are certified with, i think the pop charger will pass visual for the same reason too.
Old Nov 10, 2006 | 02:50 PM
THE TECH's Avatar
THE TECH
Nismo cats and Stillen cats are not CARB legal. Not sure where you got that info. There is no such thing as a CARB legal cat for the Z. The popcharger is actually 50 state legal.
Old Nov 10, 2006 | 03:00 PM
nebolic's Avatar
nebolic
i thought the JWT turbo is CARB legal?
nebo
Old Nov 10, 2006 | 04:17 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
i think he was referring to the exhaust system
Old Nov 10, 2006 | 10:50 PM
cvt's Avatar
cvt
exhausts do not get a carb #. basically if does not delete the cats and it complies with the 95db rating then it's legal.
Old Nov 11, 2006 | 03:21 PM
THE TECH's Avatar
THE TECH
nebo
There is no CARB legal turbo kit on the market.
Old Nov 11, 2006 | 07:42 PM
Gary King's Avatar
Gary King
K & N Typhoon is CARB Approved. How about a crank pulley, clutch/flywheel combo and tuning?
Old Nov 13, 2006 | 08:14 AM
nebolic's Avatar
nebolic
O rly?
http://www.jimwolftechnology.com/news.asp
Scroll to the middle of the page, said they are working on carb legalization.
quote from the web site
"Below is the 350Z engine layout. The street kits will be ready to ship once the CARB certification process is complete. Note the intercoolers on the 350Z below. A completely integral center casting was designed to achieve a near perfect flow to the throttle tube, while using the maximum frontal area of the stock body nose. No stock parts including bumper bar or air bag sensors are moved or modified! Also note that all of the fluid bottles retain the stock locations."
not sure what to make of JWT's advertisement . . . but I think it's leaning towards telling consumers there kits are CARB LEGAL.
nebo
Old Nov 13, 2006 | 09:02 AM
charlie_rdstr_Z
O rly?
nebo
noob
Old Nov 13, 2006 | 10:07 AM
THE TECH's Avatar
THE TECH
^^+1. Noobs need to really search and find out the real deal instead of shooting off their mouths like jackasses.
Old Nov 13, 2006 | 10:35 AM
nebolic's Avatar
nebolic
not carb legal yet but they're working on it, no?
and thanks for the jackass comment, makes me feel so welcome here.
nebo
