Vallejo Z GTG - Wednesday
Lookin' Good Ritz...
... I'll look again tomorrow...
todays been booorrringgg...
...Tomorrow will be the maiden run of my wheels... I'll be at Starbucks around 3PM or so... Hopefully, I don't beat them up that bad... From the looks of it, I will need to raise the car a little bit...
Everyone see my feeler for my wheels in the nor cal section. Ritz I need to borrow your stockies if I do sell them!! please!! Which center caps are thoes?? I like.
They are the SF-Challenge CAPS - Best ones EVER!!! I'll be more than happy to loan them... Just so you know, the rears are worn and I mean really worn... You can drive with them just fine in a straigt line but when you throtle up in/after a turn they break loose really easily
Good luck with the sale... What will you be getting next?
...Good luck with the sale... What will you be getting next?
Originally Posted by SHICHIROU
same wheels probly but in mag blue...its all good...just need something to take me to and from work till i get my new ones. I hope they clear the BBK
nice man, gives me more motivation to slam my $*** hahah. Someone got to the diffuser before I did so looks like that cash I was plannin on using is going to some coilovers. =P
Originally Posted by 415mm
ritz them wheels look pimp on the z... just keep the ride slammed and do the negative camber like I want you too. either that or drive everywhere going 5 mph. haha.
... That should give me some more time to figure out where to get my fenders re-rolled...
^just raise you're Z up like them scrapers with the 24 inch wheels do bro. looks like you're not going to be giving that girl a ride in the Z for a while huh. lolz.
... Shes really nice to me and shes great company... I guess Ill just have to use my truck more
let me know where u go for your fenders
Sigh... 285's are just so "beefy" it was hard to resist
here's that place some people are recommending on g35driver.com i guess they do it right. heatgun and all. http://www.licmotorsports.com/main.htm
its in novato about a 35 minute drive. kinda pricey though.
And I wasn't being mean. that girl looked pretty good ritz.
I know, you werent... Its all good
Hey all after going for a short drive and an I80 run, I'm glad to say that only the passenger side rubs.
I can now confirm that a 285/35/19 BFG KDW NT will fit with a good roll and some negative camber (less than 3 degrees) on GTS with a full drop on Cusco Zero 2's...
Hey James, I won't need a roll after all. I found my bat last night. I can see where the fender and the tire meet. I accomplished this with some water based paint smeared on the inside of the fender. Its all over the rear by at least now I know exactly where to roll/pull.
Damn, I would go with you but the 16th... I can't go do stuff on that day till I'm done with work (630PM)... I don't mind the re-roll for piece of mind. I did some adjustments (with the bat) when I got home and funny as it sounds it actually worked
... I don't rub anymore!!! I'll adjust my suspension while the car is on jackstands - I want to raise it up a little bit... There is this speed bump at Kaiser that always, ALWAYS gets me
LIC Motor good place. Awesome rig they have. I had just rolled my fenders before that place was posted up on Driver. $60 bones/side not that bad really.
Ah...the ole baseball bat rolling fender trick.
I used a 1.5" piece of ABS pipe when I did mine.
http://www.g35driver.com/forums/showthread.php?t=136758
Pix of mine on post#38
I used a 1.5" piece of ABS pipe when I did mine. http://www.g35driver.com/forums/showthread.php?t=136758
