DC sport headers
I was wondering if anybody has this on their Z already, because I just purchased these items. I just wanted to know since the heat shield had to be removed should I be worried about a temperature increase in the engine bay or any other adverse effects???
I have a set of DC headers installed and the engine compartment is warmer than with the standard exhaust manifolds and shields. I wrapped the fuel/vapor lines (passenger side) and the AC line (driver side) in a DEI heat shield. I also applied an adhesive heat shield to the firewall/floorpan underside to keep the foot wheel areas cooler. Headers generate much more heat than a standard exhaust system and you don't want anything to melt.
The DEI heat shields and mating are available through HRP World or any race car parts supplier.
I would recommend getting a header wrap. It is going to produce quite a bit more heat, but not to the point that anything is going to catch on fire. I have seen a few melted wires, and hoses but as I said wrap the headers before install and it should be ok.
