GT Motorsports Short/Long Blocks
Old Dec 27, 2006 | 01:49 PM
atlsupdawg#2's Avatar
atlsupdawg#2
Damn those pics make my mouth water. I'm ALMOST there and wanna drop some coin today but I can't, damnit Promised myself I would take a logical approach to this project.
Sam, you've hereby earned the label my old girlfriend used to have in the day....
TEASE
Old Dec 27, 2006 | 02:12 PM
PumpedVA's Avatar
PumpedVA
Congratulations Sam and the GT motorsports crew. Love my motor
Old Dec 27, 2006 | 07:07 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Hi Guys
Some answers on power goals.
It really depends on what the intended use of the car is. If you are building a street car that is going to running 13 to 15 PSI stage 1 block will be more than adequate and will be able to accomplish 500 to 550 WHP on 91 octane. If the plan is to run 18 psi and beyond I would recommend a stage 2 block. That being said, to this day we don't really have any scientific hard data as far what is the limit of the stock block/when is it that sleeves becomerequired. Most the the tear downs that we have done on built motors that have failed are the result of workmanship issues, like incorrect machining/final assembly/tuning issues. Little further down the road when we start taking apart built z engines that had survived the machining/assembly process AND survived tuning, with 30 to 50 k miles of hard use without catastrophic failures, we can really determine how well a unsleeved vq is taking the ware and tare vs. a sleeved engine.
Old Dec 27, 2006 | 07:39 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by BrianLG35C
Thanks again Sam, for our recent phone conversation regarding your head packages. How much $ for the above option and what year of the VQ is this TSB referring to? How much to get a long block core included?
you must hold the record for longest downtime on a motor
Old Dec 27, 2006 | 07:58 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Originally Posted by brooke
! question though, I'm interested in the coolant mod you did on the motor?? Care to give any
details on how too??
The cooling mod comes from a Nissan pathfinder 4x4 that is equipped with the tow package, its a group of oem parts that bolts right on the back of the engine witch include a secondary thermostat system that allows more coolant circulation when temp reaches 95 c .and we do cell this mod as a complete kit .
Old Dec 27, 2006 | 08:01 PM
Beer Goggles's Avatar
Beer Goggles
What is stage 0 good to? I'm just looking to get about 400-450whp, nothing crazy.
Old Dec 27, 2006 | 08:16 PM
zman1910's Avatar
zman1910
There really isn't a difference btw stage 0 or 1...as far as power levels are concerned. Just has some cheaper(but still good) rods.
Old Dec 27, 2006 | 08:23 PM
Kam350z's Avatar
Kam350z
Hey Sam you are the best. Nobody is more dedicated and precise at what they do like you are with your work. Remember me? I'm Kam, the guy whos N/A Z you tuned. I'll be coming down soon enough for further modification once I start making good money again ...
Old Dec 27, 2006 | 08:27 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
The TSB is to address a momentary noise after a cold start from the timing cover area,it get mistaken for a timing chain tensioner or guide ,there is a spring that keep tension on the VVT sprocket ,the spring brakes or get weekend witch will cause the noise ,these sprockets are not cheep there are about $500 give or take each .I will scan the TSB and post it here . we have seen this problem mainly on the early 03-04 models .
Old Dec 27, 2006 | 08:29 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Thumbs up
Absolutely correct
Old Dec 27, 2006 | 09:26 PM
sugarspunZ's Avatar
sugarspunZ
awesome work Sam. i keep having dreams about my car once its done.
Old Dec 27, 2006 | 10:33 PM
Nitrouz's Avatar
Nitrouz
Back to Z
amazing packages, killer deals for what you get. Great work Sam!
Old Dec 28, 2006 | 12:28 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Wow! How much is the core charge? Also, the wiseco pistons used in stage 0 isn't the same wiseco pistons from any other shops? Lastly, can I choose compression ratios as well?
Old Dec 28, 2006 | 08:55 AM
zman1910's Avatar
zman1910
+1.....stage 0 here I come. Great pricing and great quality
Old Dec 28, 2006 | 09:39 AM
BrianLG35C's Avatar
BrianLG35C
I probably do and it's killing me!
Old Dec 28, 2006 | 09:46 AM
BrianLG35C's Avatar
BrianLG35C
Thanks, I do have an early 03' model. How about the core charge?
Old Dec 28, 2006 | 10:38 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
The GTM extreme WISECO pistons are all costumes pistons made to our specifications, they are not the off the shelf piston that you can by from WISECO .in a matter of fact if you set the arias extreme next to our GTM WISECO piston you could not even tell the difference.as far compression ratio goes any thing you can think of we offer.
Old Dec 28, 2006 | 03:27 PM
  #38
GTM's Avatar
GTM
Vendor - Former Vendor
Hey Brian,
As stated the Sprockets are appox $500 ea. and applys to the 03-04 model VQ35 engines. I would recommend that you try and source out your own longblock for a core if you need a new block. Prices are usually $1,500 to $2,200. But if you need one I think we have a few in stock
Let me know if you have any other questions!
-George
GT Motorsports
Old Dec 28, 2006 | 03:36 PM
  #39
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by George@GTM
Hey Brian,
-George
GT Motorsports
you guys still didnt get shelves where's the second story storage??? come on guys... next time I'm there I want to see alphabatized organization
Old Dec 28, 2006 | 03:37 PM
  #40
sugarspunZ's Avatar
sugarspunZ
in terms of compression ratio why would one go with 9:1 vs 8.5:1 or 8.0:1 or anything else.
sorry if this is a newb question.
