GT Motorsports® Spec Exedy® Carbon Series clutches
Old Feb 13, 2007 | 06:46 PM
GTM's Avatar
GTM
Vendor - Former Vendor
Yup, just need to make time to get it weighed
Old Feb 13, 2007 | 07:01 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Sounds good...looks like a real quality unit...too bad I already bought a twin disc clutch...
Old Feb 13, 2007 | 08:11 PM
meatbag's Avatar
meatbag
What features of the clutch are proprietary to GTM? I've seen other shops that have the sprung hub version for sale.
Old Feb 13, 2007 | 11:08 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
You bring up a very valid question and it is important that people know this. Its seems to be a major misconception that the GT Motorsports® Spec Exedy® Twin Disk Carbon Clutch (PN:NT01HDMC) is the same unit as the other twin disk carbon clutch being sold online by other vendors. This is definitely NOT the case as the GT Motorsports® Spec Exedy® Twin Disk Carbon Clutch is the only one currently available for the VQ35 that offers the sprung hub with its patented spider cog drive damper design. The other Exedy twin disk carbon clutches currently available (PN:NM072SBMC) for the VQ35 DO NOT offer this feature which make a huge difference in feel, grab, and drive train shock resistance. To answer your question there is a graph below from Exedy Japan that shows the GT Motorsports® Spec Exedy® Twin Disk Carbon Clutch having the MOST clamping force and power capacity out of all the other Exedy clutches currently available for the VQ35.
Bottom line is the GT Motorsports® Spec Exedy® Twin Disk Carbon Clutch is the BEST clutch you can purchase from Exedy for the VQ35 Platform.
As stated before this clutch is ONLY available through GT Motorsports and no where else, therefore it is IMPOSSIBLE to get this setup anywhere else, regardless of what others may tell you, part numbers don't lie.
Hope this clears everything up,
Sam
PS: The GT Motorsports® Spec Exedy® Twin Disk Carbon Clutch is Highlighted in BLUE.
Old Feb 13, 2007 | 11:13 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Originally Posted by turismo
I ended up purchasing the twin carbon carbon disk through SGP. Very nice clutch!
You then must have the non-sprung version of this clutch as that is the Part number listed on there website, therefore it is not the same clutch we are selling. Nonetheless you have a good clutch in your car
Sam
Old Feb 15, 2007 | 09:45 PM
GTM's Avatar
GTM
19.6 FLYWHEEL ONLY! EDIT**
Please let me know if you have any other questions.
-George
GT Motorsports
Originally Posted by Dave 90TT
Ok, like I said, what is the weight of the flywheel, then?
Old Feb 15, 2007 | 10:57 PM
sentry65's Avatar
sentry65
the burninator
but how much is the flywheel by itself without the rest of the assembly?
Old Feb 16, 2007 | 03:10 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
19.6 Lbs complete Assembly, Hope this helps.
-George
GT Motorsports
wow..that's REALLY light...
My Carbonetic twin is around 23lbs for the full assembly.
Old Feb 16, 2007 | 05:42 AM
gringott's Avatar
gringott
What throwout bearing are you using with this clutch/flywheel combo?
Old Feb 16, 2007 | 05:44 AM
Nealoc187's Avatar
Nealoc187
Nice clutch. I just had one of the tech guys from Exedy in the shop yesterday dropping off the transmissions for both his rally car and his drag car and talked to him for a bit about Exedy's clutch offerings for the 350Z.
Old Feb 16, 2007 | 10:13 AM
KempieZ's Avatar
KempieZ
I will definately order one in time. I will order it with the gearbox.
Old Feb 16, 2007 | 12:55 PM
GTM's Avatar
GTM
Let me know this Special Pricing is only temporary....
-George
GT Motorsports
Old Feb 17, 2007 | 08:08 AM
GTM's Avatar
GTM
19.6 is for the flywheel alone, I was a bit tired when I made the other post and posted 19.6lb as the whole assembly, oops! I will get the entire assembly weight as of now all I know is the flywheel is 19.6lbs. Thanks again and sorry for the confusion!
-George
GT Motorsports
Old Feb 17, 2007 | 08:51 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Huh, okay. Thats actually kind of heavy for a lightweight flywheel. Oh well.
Old Feb 17, 2007 | 09:08 AM
GTM's Avatar
GTM
Actually it is still much lighter than stock, while still maintaining very quite operation and stock like feel when compared to other clutch/flywheel combos able to handle close to this amount of power. There is such thing as too light (trust me I used to own a tilton setup on my Z ) On a FI car a 19lb flyhwheel is actually an advantage since it makes it easier to drive and launch the car if you are drag racing.
Anyways I am not trying to convince you to purchase this clutch from us, but rather for you to continue to research other options available to you and I think you will find this is the best clutch out there for the VQ35 platform.
Thanks!
-George
GT Motorsports
Old Feb 17, 2007 | 10:07 AM
gringott's Avatar
gringott
In comparison, my NISMO flywheel is 23 lbs.
George, again, what throughout bearing do you use with this setup?
Old Feb 17, 2007 | 10:56 AM
GTM's Avatar
GTM
Sorry I missed your question the first time, We are using the OEM bearing.
HTH,
-George
GT Motorsports
Old Feb 19, 2007 | 01:32 AM
  #38
Nitrouz's Avatar
Nitrouz
Back to Z
drove it yesterday...
I had the ATS Dual Carbon with 1350kg PP before, and I hated it so much I had to sell it. Went with a JWT instead since my power level was low. I was scared to ever step to another carbon clutch again because of how hard they drive.
It took Sam A LOT of convincing to get me to try this clutch out, which I did. Honestly, I was so excited to drive my car again, I totally forgot about the clutch. It held, it slipped when I wanted it to, I completely forgot it was there even though I was in the crazy LA traffic.
This clutch is really amazing imo. I'm completely in love with it.
Thanks Sam!
Old Feb 19, 2007 | 01:37 AM
  #39
GTM's Avatar
GTM
I had the entire assembly weighed in and it came out to 36.9lbs. Very good for a complete assembly that can hold this much force!
Thanks again everyone, a few clutches will be shipped out this monday, you know who you are
-George
GT Motorsports
Old Feb 19, 2007 | 08:08 AM
  #40
discom's Avatar
discom
I had the entire assembly weighed in and it came out to 38.9lbs. Very good for a complete assembly that can hold this much force!
-George
GT Motorsports
Spoke to Sam...pls remember to keep one for Singapore
