Shop Builds Temp moving posts for some clean up of this section.
Forged Performance: Another 600whp+ meth setup
Old Dec 26, 2007 | 08:39 PM
Hexxum001's Avatar
Hexxum001
Originally Posted by Jay'Z
Thats sick!! have to do it though.......
Agreed! We need some pix!!
Old Dec 26, 2007 | 09:03 PM
TheBlackPearlZ's Avatar
TheBlackPearlZ
looks awesome sharif!! congratz chad!! and yes please with some pics!
Old Dec 26, 2007 | 09:07 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Very Nice!
Nice power, and quick spool up!
I wonder what a APS extreme TT kit maxed out with some dual pumps, and some meth and C16 would do??
Old Dec 27, 2007 | 05:58 AM
Philthy's Avatar
Philthy
Boost Junkie
Very nice power curve...
Old Dec 27, 2007 | 06:46 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I see another one coming very soon!
Old Dec 27, 2007 | 07:24 AM
dutchboy's Avatar
dutchboy
Originally Posted by eagletanggreen
Very Nice!
Same here .
Old Dec 27, 2007 | 08:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
So what turbo kit is this?
Old Dec 27, 2007 | 08:11 AM
Sharif@Forged
Forged Performance
Ask, and you shall recieve.
Old Dec 27, 2007 | 08:14 AM
maximumsportZ's Avatar
maximumsportZ
Great work Sharif,
Did you remove the bodykit from your car?
Old Dec 27, 2007 | 08:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
So its a Greddy kit, this must be DZ350's car? Dil? Upgraded turbos?
Old Dec 27, 2007 | 08:26 AM
eagletanggreen
Got Track!!!!!
Clean install!
Old Dec 27, 2007 | 08:35 AM
doug's Avatar
doug
i thought he said Chad? and Dil has a full do luck kit
Old Dec 27, 2007 | 08:49 AM
XKR's Avatar
XKR
Sharif.....
How does this system differ from Louie's? Louie has controls inside. How is this system activated?
Not that I am interested in getting one
Old Dec 27, 2007 | 09:44 AM
Jay'Z's Avatar
Jay'Z
Thats ****ing sick!! I love it..... Damn.. If i lived in GA id be dropping my car off time now.......
Old Dec 27, 2007 | 04:44 PM
rrmedicx's Avatar
rrmedicx
Is this the kit you used?
http://www.snowperformance.net/product.php?pk=8
If so it appears to be run specifically off of manifold boost pressure. Is this set-up actrivated by the UTEC, or is it set-up to run via boost signal alone?
Great Power...Congrats!
I hope to make similar power when all is said and done. With the addition of Meth to keep temps down and running what some might refer to as "safer".
Old Dec 27, 2007 | 05:10 PM
jumpin800agl's Avatar
jumpin800agl
8 to 11
excellent power on pump gas. Must be one hell of a rush when you press the go pedal. Great job Sharif!
Old Dec 27, 2007 | 07:01 PM
athenG's Avatar
athenG
Was that the standard tank? I would've use their 7qts tank since you have lot more space in the trunk. I thought you need another solenoid if you put the tank in the trunk.
It is safe if you are not changing anything but in this case Sharif did lean out just a little and added more timing. If the kit fail then that is trouble. I did some research with Utec and Meth kit and the best you can do is just turn on/off the kit using the spare Solenoid. You still need to tap of the Manifold to progressively spray, I don't think Utec has any signal you can tap for Boost.
Old Dec 27, 2007 | 07:30 PM
  #38
Hexxum001's Avatar
Hexxum001
Very nice job Sharif. Thanks for the pix!
Old Dec 27, 2007 | 07:35 PM
  #39
rrmedicx's Avatar
rrmedicx
I am hopeful that when the time is right and I can upgrade from the UTEC to PROEFI that the meth system I choose can be controlled with precision safety in mind, so that if the meth runs out, the computer/EMS will get a signal and cut power or timing to avoid damaging the engine.
I am still hoping to find out if it is activated by manifold boost pressure alone. I would think that if the system comes with a computer it could deliver meth a little more precisely. But who can argue with 600rwhp. Thats impressive.
I wonder how difficult it is to tune with Meth? Where do you start? Is it common to change jet sizes during tuning?
Any advice Sharif. Not too many others promoting the meth tuning...
Old Dec 28, 2007 | 10:38 AM
  #40
Sharif@Forged
Forged Performance
No, a solenoid is not needed for trunk mount. If the pump is mounted higher than the tank, then they recommend a solenoid.
Yes, this is their boost cooler 2 system. It is trigged via manifold pressure, directly from the controller.
