Shop Builds Temp moving posts for some clean up of this section.
Lethal Injection: 05blakz33's Rb26 Swap
Old Sep 21, 2009 | 02:00 PM
  #61
05blakz33's Avatar
05blakz33
Originally Posted by cc1012
Nice build..... RB is meant for boost. If done right youll prob have a more reliable car then someone with a built VQ and twins.
Since this will be my daily driver that is the plan
Old Sep 21, 2009 | 08:57 PM
  #62
drkz33's Avatar
drkz33
Loving the write up and pics. Looks like you guys have been making good progress and everything is looking good. Best of luck to getting it running soon and driving it to work or using it as your grocery getter...lol
Old Sep 21, 2009 | 09:11 PM
  #63
rogueeg6's Avatar
rogueeg6
this is sick, me and a friend have a spare Z body. might have to look into something like this
Old Sep 22, 2009 | 02:03 AM
  #64
05blakz33's Avatar
05blakz33
haha ya, Drive Shaft came in today , fit perfectly , now im just waiting on my slim fans that come in today and a new shifter next door at the machine shop
Old Sep 22, 2009 | 02:13 AM
  #65
jumpin800agl's Avatar
jumpin800agl
8 to 11
should be an interesting build. Nice to see some other stuff coming out of Atlanta area also.
Old Sep 24, 2009 | 01:58 PM
  #66
sanders711's Avatar
sanders711
very nice!
Old Sep 28, 2009 | 04:17 PM
  #67
Coffeemaster's Avatar
Coffeemaster
Why would you put a 800lb engine in place of the VQ when you could of just done a LSx swap?
JDM tyte right? Have fun with your weight distribution.
Old Sep 28, 2009 | 06:44 PM
  #68
05blakz33's Avatar
05blakz33
Because it wasnt what i wanted and we weighed the motor side by side it was like 130lb difference after all the unneeded material was machined off. JDM tyte..? Why would i care if it was JDM lol, Isnt a Japanese car JDM as is? If i cared what people though about id listen to people like you and get an LSx swap
Old Sep 28, 2009 | 07:50 PM
  #69
Coffeemaster
130lb difference? Really? The Crate VQ weighs 313lbs, a crate RB26 weighs 540~lbs or so. Granted its not the 800lbs I stated (I was including transmission) its still quite a bit heavier then a regular VQ, and much longer.
I'm wondering why you went with a RB instead of something else, and what your reasoning was, and most of the replies I get is because its "JDM".
In all honesty, it seems like its just an old cast iron engine that people think is legendary because it was used in an old skyline. Yeah, you can make power with them, but the cost of entry, cost of parts, and the cost to maintain, its not a very good engine in comparison to a LSx.
Old Sep 28, 2009 | 08:55 PM
  #70
S12 driver's Avatar
S12 driver
The RB is a motor designed for boost from the factory, and it's pretty overbuilt. The VQ is more efficient but definitely not as overbuilt. You see a lot of stock internal boosted VQ blowing up with only low 400whp, the RB26 should be able to take a lot more.
Old Sep 28, 2009 | 09:46 PM
  #71
Zexy's Avatar
Zexy
LOL completely ignorant statement. Ask a real knowledgeable skyline person about this. They will tell you otherwise. Been there, done that to an extent and spent $ for it.
Old Sep 29, 2009 | 03:40 PM
  #72
05blakz33's Avatar
05blakz33
Yes really. Cutting off the front diff for the RB26 + stronger / lighter custom sub-frame, all other mounts /supports and shaving off material here and there adds up. Not to mentioned the intercooler makes up part of my core support so it helps with the weight difference up front. As for it being much longer thats BS the motor sits in the engine bay perfectly with out having to mod the fire wall and still leaves 2" clearance before fitting the fan shroud.. it also sits a lot lower then the VQ. The reason i went with the RB is because in my personal opinion the power band on the VQ was too short i wasn't fond of the gearing and in all honesty i like the way an RB drives over the VQ not to mention i got an amazing deal on the swap... I could care less if something is JDM.
As for the old cast iron engine that's an opinion and you are more then entitled to it But as for me i rather use an engine that was meant for boost with out having to drop the same amount of cash i payed for my swap to build a motor that i wasnt very fond of. The motor is expensive for a reason and its more then just an opinion
Old Sep 29, 2009 | 05:33 PM
  #73
BornSlippyZ's Avatar
BornSlippyZ
+1 I agree.
Old Sep 29, 2009 | 05:50 PM
  #74
Coffeemaster
Thank you for having an actual reason rather then being some jackass that went with it because someone told them to. I wholeheartedly agree that the VQ band is garbage and in general is a waste of time/money/effort to mod. Forgive me for jumping to conclusions when I saw someone else doing yet another RB swap.
I agree that the RB is a better engine then the VQ, but I don't think its any better then a LS engine,
Pics of the engine bay, tell me what you did to the bay too. From the swaps I had seen they mount it fairly high up and it sits quite a bit over the front support.
Old Sep 29, 2009 | 09:32 PM
  #75
05blakz33's Avatar
05blakz33
Its no problem and dont get me wrong, the LS is an awesome motor! I have a friend that has it in a civic catch and a few in a 240 (s13 & s14 ) for instant power the motor is great but i like boost better and for a daily driver the RB is more then enough. I also know what u mean about the JDM thing. It seems like every forum i the subject of an rb26 in a 350z is always brought up then dies down after no one ever goes through with it. I did manage to talk to a few of the shops in the US that have done it in a G35 and 1 in a 350z ( actually completed and running of cores ) and some did pointless things like cut off the whole front end even tho the stock one bolts off and didn't sit the engine low enough because they decided to keep the sub frame and just make mounts. When you look at the motor head on it looks like the hood will hit it but once you place the strut bar on you can clearly see it sits lower then the VQ.
Old Sep 30, 2009 | 12:13 AM
  #76
Andrei's Avatar
Andrei
I'm in Lawrenceville GA. Let me come by and get some pics and vids some time this week??? PM sent.
Old Sep 30, 2009 | 01:58 AM
  #77
05blakz33's Avatar
05blakz33
replied
Old Sep 30, 2009 | 06:17 AM
  #78
CRIDDA's Avatar
CRIDDA
Ok now, get this done. I am tired of waiting
Any clue when she will finished up?
Old Sep 30, 2009 | 12:35 PM
  #79
05blakz33's Avatar
05blakz33
Before the 14th
Old Oct 6, 2009 | 03:38 PM
  #80
Chomorro's Avatar
Chomorro
Wow nice stuff, i wonder how this would compare with a 2jz swap in price and driveability.
Good job
