So it now time to get new wheels need help with offset.
Old 05-15-2016, 03:26 PM
ssmokeyy
ssmokeyy's Avatar
I do like the Enkei Kojins wheels in black. So now I have my wheel and tire setup.
Thank u guys. Would it be better to go 245/40 265/40 tires or 255/40 275/40 tires. The tires I want to use are the new nitto nt555 g2.
Old 05-15-2016, 03:32 PM
Received 9,099 Likes on 6,556 Posts
55 and 75 combo
Old 05-15-2016, 03:33 PM
Originally Posted by ssmokeyy
I don't know I would say made up but I think 25mm front and 20-25mm on the back would be about prefect after talking with every one today about this. Does the offset change if I want to do deep dish wheels?
the bold wouldn't be bad
Old 05-15-2016, 05:59 PM
ssmokeyy
ssmokeyy's Avatar
So this 275/40 255/40 combo Is making a new problem. I want to use nitto tires and they don't make a nt555 g2 in 255/40. And they don't make one in the nt 05 either. They do make a 245/40 and 275/40 in the nt-05. So its either I use two brands of tire or 245/40 front with 275/40 in the rear. What do u guys this about this problem?
I found they have a match with 275/35 rear 255/35 front? Will that upset the car?
Old 05-15-2016, 07:58 PM
Received 3,271 Likes on 2,328 Posts
18" Sizes
225 45% 18 25.97 Stock Reference Size
245 45% 18 26.68 Stock Reference Size
245 40% 18 25.72
255 35% 18 25.03
255 40% 18 26.03
255 45% 18 27.04
265 35% 18 25.30
265 40% 18 26.35
275 35% 18 25.58
275 40% 18 26.66
285 30% 18 24.73
285 35% 18 25.85
285 40% 18 26.98
295 30% 18 24.97
295 35% 18 26.13
295 40% 18 27.29
305 35% 18 26.41
Most popular 18" sizes of wheels for Z Cars:
Front: 18x9.5 +15 to +25
Rear: 18x10.5 +15 to +25
Neither will require fender work.
Why are you limiting yourself to one brand tire anyways?
Old 05-15-2016, 09:01 PM
ssmokeyy
ssmokeyy's Avatar
I used a lot of tires and want to try nitro this time. The best Tire I have used is the super sports, than Bridgestone really line, than bfg GeForce, Hankook v12 Evo hated this tire.. I think I'm going to do the same setup I have now. Super sport tires on the front and nitro nt555 g2 on the rear. The super sport tires really hold the road.
Old 05-15-2016, 11:49 PM
NOT a good idea mixing tires. I mean, it's not like doing so is going to make you slide off the road or anything so long as performance capabilities of each brand of tires is comparable but..... performance and predictability of your mis-matched set is NOT optimal with different rate of adhesion drop-off, rollover rates, etc.
If you can swing it, get a full set of Michelins and call it a day, can't go wrong with the PSS. Just my take.... you do what you ultimately want.
Old 05-16-2016, 10:39 AM
ssmokeyy
ssmokeyy's Avatar
Is 255/35 front 275/40 Bad idea for this car?
Old 05-16-2016, 01:18 PM
I already posted up the tire size chart. Look at it carefully. I even color coded it. Look specifically at the last number of each row. That's the overall height spec and compare to the reference tire.
Old 05-16-2016, 01:41 PM
Well......what if he is color blind mic
Just sayin
Old 05-16-2016, 04:20 PM
Just sayin
Hush, Trav.
Empirical evidence doesn't need color.... it's black and white. Ar ar ar ar...
travlee (05-16-2016)
Old 05-16-2016, 04:23 PM
TheeVirtuoso
North Central Marketplace
06-20-2016 07:32 PM
mcubed45
05-14-2016 10:36 AM
Beerdo
05-11-2016 12:29 PM
Wheels Tires
05-03-2016 03:48 PM
Quick Reply: So it now time to get new wheels need help with offset.
