Wheels & Tires Wheels, Tires, Big Brakes, Coilovers, etc...
Ichiba Wheel Spacers...5/10/15/20/25/30/38mm Version 1 and Version 2 Available!!
Old Feb 12, 2010 | 12:34 AM
mrwong@statik's Avatar
mrwong@statik
Vendor - Former Vendor
Default Ichiba Wheel Spacers...5/10/15/20/25/30/38mm Version 1 and Version 2 Available!!
New Version 2 30mm and 38mm Spacers Available!!!
Looking for Spacers? Everywhere not cheap enough? Well look no further.
Shoot me a PM and I'll be more then happy to hook you guys up!
Description:
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Spec:
Bolt Pattern: 5/114.3
Center Bore: 66.2
Thread: 12x1.25
Longer Studs Included
Sold as one pair (2pcs) with 10pcs longer studs.
Ichiba NS-50205 Spacer V1 5mm
Ichiba NS-50210 Spacer V1 10mm
Ichiba NS-50215 Spacer V1 15mm
Ichiba NS-50220 Spacer V1 20mm
Description:
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Spec:
Center Bore: 66.2
Thread: 12x1.25
Note:
Sold as one pair (2pcs) with 10pcs nuts
Ichiba WS-25511466A Spacer V2 15mm
Ichiba WS-25511466B Spacer V2 20mm
Ichiba WS-25511466C Spacer V2 25mm
Ichiba WS-25511466D Spacer V2 30mm
Ichiba WS-25511466E Spacer V2 38mm
~PM~ For Pricing too low to post!
Old Feb 16, 2010 | 10:20 PM
mrwong@statik
pms replied
Don't forget to check out
www.statikperformance.com for our Latest Brand List!
Old Feb 17, 2010 | 09:57 PM
mrwong@statik
pms replied...
Check out www.statikperformance.com for our Brand List
Old Feb 24, 2010 | 09:25 PM
mrwong@statik
pms replied..
Be sure to check out
Overstock/Clearance Section coming soon!!!
Old Mar 8, 2010 | 03:02 AM
mrwong@statik
PMS replied..
Old Mar 16, 2010 | 06:49 AM
z33allme's Avatar
z33allme
version 1 shipped to 78245
Old Mar 17, 2010 | 09:49 PM
mrwong@statik
pms replied..
Old Mar 17, 2010 | 10:02 PM
theianmcdougall's Avatar
theianmcdougall
how much for 2 pairs of 10mm spacers shipped to 70506
thanks
Old Mar 18, 2010 | 01:58 AM
tsGeekzStylez's Avatar
tsGeekzStylez
how much for 10mm spacers picked up
Old Mar 18, 2010 | 01:14 PM
mrwong@statik
pms replied..
Old Mar 23, 2010 | 11:47 PM
mrwong@statik
pms replied...
Old Mar 29, 2010 | 03:27 AM
mrwong@statik
pms replied..
Old Apr 2, 2010 | 02:01 AM
mrwong@statik
pms replied...
Old Apr 8, 2010 | 11:11 AM
NyCSnEaK's Avatar
NyCSnEaK
Order placed this morning for V2 30mm.
Old Apr 8, 2010 | 11:54 AM
carlili4190's Avatar
carlili4190
to 60521 please
Old Apr 13, 2010 | 01:33 AM
mrwong@statik
pms replied..
Old Apr 17, 2010 | 12:39 AM
coolblue830's Avatar
coolblue830
ichiba v2 20mm shipped to 94080 please
Old Apr 19, 2010 | 01:06 PM
TPete19's Avatar
TPete19
How much for a pair of 20mm V2's and a pair of 25mm V2's shipped to 98072?
Old Apr 19, 2010 | 01:15 PM
aRYip's Avatar
aRYip
5mm and 10mm shipped to Toronto M1H3J7
Old Apr 20, 2010 | 01:47 AM
mrwong@statik
pms replied..
