Springs, Shocks and Coilovers kits (Tein, BC Racing, Tanabe, Eibach and Tokico)
Old Feb 20, 2010 | 08:22 PM
B2autodesigns's Avatar
B2autodesigns
Vendor - Former Vendor
Default Springs, Shocks and Coilovers kits (Tein, BC Racing, Tanabe, Eibach and Tokico)
Hello Guys,
We offer the full-line up of Suspension upgrades for you 350z. We have over 25+ years experience. Please pm me or give us a call 813-787-4075 with any questions you might have. Check out below the products we offer at great pricing for forum members:
Got a nice package deal guys:
Tein S-Tech 350z springs and SPC rear camber kit w/toe bolt. $329.00 shipped.
Tein H-Tech 350z springs and SPC rear camber kit w/toe bolt. $329.00 shipped
SPC camber kits:
Need your SPC camber kits in a hurry. No need to worry. Free 2nd day air shipping upgrade. Get them fast!!!
After lowering the ride height of your G35. Excessive negative camber can actually hurt your traction, tire wear and cornering performance. The complete SPC Pro-Alignment front and rear camber w/rear toe kits replace the limited stock alignment adjustment and let you fine tune the handling and traction characteristics of your car. Now you can set up your ride for any driving scenario, from the street to the strip and anything in between. These kits will NOT fit cars with active steering
Applications we stock!!! Front and rear kits. Please pm for best pricing
03+350Z
09+370z
Whiteline 350Z 03-08 Front & Rear Vehicle Essentials Kit. Essentials Kit; Contains Whiteline part numbers KDT911, W52988, W52991, W52992 & W83389. Message me for best pricing.
Tein 03-07 Infiniti G35 Coupe / 03-06 G35 Sedan V35 / 03-08 Nissan 350Z Z33 Street Basis Coilovers (part#GSP26-1UAS2)
The Street Basis damper is the evolution of the popular BASIC coilover. Developed to provide a sporty ride feeling and aggressive stance. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Vehicle ride height is adjustable via the ZT coated threaded sleeve. Updated internal components and external coatings increase durability and product life. Street Basis dampers are great for daily driving and spirited driving for all types of drivers.
Made in Japan under strict quality control standards and developed by highly trained suspension engineers.
Steel Construction
• Twin Tube internal construction
• Larger piston diameter for strut type front and rear (22mm)
• Ride Height adjustable via spring seat
• Powder coated damper body
• Non-welded ZT coated Adjustment Tube
• Full-Length Dust Boots
• 1-piece Aluminum Spring Seat with Delrin Thrust Washer
• Available for Overhaul
• 1-year Manufacturers Defect Warranty
KW Coilovers kits IN STOCK. 350Z and 370z application. Great pricing. Please pm me
Variant 1 and Variant 2. With KW factory pre-set up dampening The ideal systems for customers wishing to rely on the experience of our engineers yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety. • Optimally adjusted, sporty and comfortable dampening technology • inox-line stainless steel technology at no extra charge • Individually height adjustable • German TUEV-tested lowering range • High-quality components for long life • Comprehensive documentation for ease of use
Suspension Techniques 03-08 Nissan 350z X Height Adjustable Coilovers
ST Speedtech Coilovers are made by KW, the leading brand worldwide for height adjustable coilover systems. In fact ST is owned by KW automotive. Just think of ST as KW’s little brother! Check second post for KW coilovers.
ST Speedtech Coilovers are constructed of high grade steel, and heavy galvanized for great rust protection.
KW Coilovers are made from INOX stainless steel, which is 100% rust free.
Stance Coilovers: Message me for best pricing.
K-Sport coilovers. 32 way adjustable. Message me for best pricing.
BC coilover kits
General:
Mono-tube shock design
30 levels of damping force
Pillowball mounts and adjustable camber plates included*
Adjustable rear camber plates available
Separate Full length height adjustable
Inverted and Non-Inverted setups
One year warranty
Rebuildable
Technical:
Coilovers use 46mm pistons and 53mm shock housings.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
Iron lower brackets on MacPherson struts to ensure rigidity
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion
BR-Type:
BC BR coilovers w/Swift spring upgrade available.
Please call 813-787-4075 for best pricing.
Package w/Eibach/SPC rear camber kit w/toe bolt $1079.00 shipped
ISC N1 Coilovers. FREE SHIPPING
Front and rear mounts.
Spring rate 12 F and 10 R.
32-Step Adjustable Dampening
Pillowball Uppermount
Piston Rod Design
Sports Springs ( Street Comfort, Street/Sport, Race/Track)
Ride Height Adjustable
Aluminum Bracket
Single Cylinder Design + More
The ISC N1 coilover can transform your vehicle into a nimble, responsive and agile machine. We offer solutions for all types of driving demands from comfortable street driving or sprinted street/ sport, to even aggressive race/track solutions for your vehicle.
Tein Springs
TEIN S.Tech Spring Kit for Nissan 350Z 03-UP -.7" Drop Front & -.6" Rear
Please pm for best pricing.
350z on Tein S-Tech springs
TEIN High.Tech Spring Kit for Nissan 350Z 03-06 -.3 Front & -.2 Rear
Please pm me for best pricing.
Tein S-Tech 09+Nissan 370z
Lowers vehicle .9" front & .8" rear. Front spring rate 8.5kg/mm & rear spring rate 9.4kg/mm.
Tein Coilovers kits We offer all Tein products for the 350z/370z.
Tanabe springs kits
The GF210 coil springs in geared towards maximum performance, without compromising daily driveability. A subtle drop provides an aggressive stance, while the higher spring rate (+20%-30% over stock).
The GF210 is well-mated with a performance shock upgrade to extract the full potential of the coil spring but will also work well with factory shocks.
Tanabe - GF210 (Grip Feeling) for Nissan 350Z 03-08 Spring Kit, 1.0 Inch Drop (FR) & 1.2 Inch Drop (RR),
Tanbe- GF210 (Grip Feeling) for Nissan 370z 09+
Lowers vehicle .8" front & 1" rear. Spring rate 8.8kg/mm front & 9.1kg/mm rear.
The Tanabe NF210 coil spring features a tastefull drop, and produces the best overall ride quality and comfort for a peformance lowering spring.
Tanabe - NF210 (Normal Feeling) for Nissan 350Z 03-08 Spring Kit, 1.2 Inch Drop (FR) & (RR),
Tanabe -NF210 (Normal Feeling) for Nissan 370z 09+ Spring kit,
Lowers vehicle .8" front & 1" rear. Spring rate 5.9kg/mm front & 6.8kg/mm rear.
Tanabe Coilovers kits
Tanabe Pro 5 Coilovers:
Fully adjustable coilovers. Message me for best pricing.
http://www.tanabe-usa.com/five.asp?id=20
Tanabe Sustec Pro CR Coilovers 350Z (Z33) .Great bang for the buck coilover kit.
Eibach spring kits
Lots of Eibach spring kits in stock ready to ship!!!
Eibach Pro Kit Springs For Nissan 350Z 03-08
Lowers Vehicle 1" Front & Rear.
Eibach Sportline Springs For Nissan 350Z 03-08
Lowers Vehicle 1.2" Front & Rear. Please pm me for pricing
Eibach Pro-kit: 370Z 09-UP
Lowers vehicle .9" front & .8" rear. Please pm me for pricing
Swift lowering springs:
Swift made Sport Springs keeps the quality ride you get from the showroom, and adds improved handling and lower ride height for driving enthusiasts and style minded drivers who demand only the best.
From HPDE events to SCCA competition, Swift Spec-R Sport Springs are made for the track enthusiast looking to take their vehicle to the next level.
Swift Spec-R Sport Springs were engineered with 3 characteristics in mind.
1.Modified ride height compared to Sport Springs to maximize optimal suspension geometry.
2.Further increasing the spring rate to enhance overall performance. The increase in spring rate is based on the upper limits of the vehicles factory shock valving.
3.Maintaining optimal comfort level for street use.
Spec R springs are wound with the same engineering and material as our sports springs. With the exception of stiffer rates and slight change in ride height; you can expect the same characteristics as our sports springs.
350z drop. 1.2"front and 1.0" Rear.
370z drop. 1.2" front and 1.0" Rear.
GTR drop. 1.0" front and 1.0" Rear
Message me for best pricing:
Koni Yellow's ajustable shocks.
KONI Sport dampers are designed for aggressive driving or cars with suspension upgrades while continuing to offer comfort. Externally Adjustable. These dampers can be adjusted, literally at the turn of a ****, a technique borrowed from Formula-1 racing where KONI dampers have dominated the field for years. One can switch back and forth, in most cases in a matter of seconds, from a comfortable "touring" setting to a more firmer setting for a sporty drive. By means of a **** damping forces can be altered to driving conditions or personal preferences.
Fits: 03-08 350Z application.
Tokico HP and D-Specs shocks back in stock. Message me for best pricing. 350z application:
Bilstein B8 shock sets. 350Z application:
If you’re looking for a performance lowering shock absorber or strut, the BILSTEIN B8 Sport Series is up to the task. Designed to enhance your car’s lowered suspension, BILSTEIN’s monotube gas pressure technology features delivers a sport ride with remarkable comfort.
*The product benefits at a glance:*
* Monotube gas pressure construction
* High-performance shock absorbers and struts designed specifically for lowering springs and production sport vehicle
* Sport-tuned with a high level of comfort
* Precision handling and optimized vehicle control
* Road-tested and fine-tuned by BILSTEIN
Please pm me or call 813-787-4075 for pricing or any questions you might have.
Also visit us online:
www.b2autodesigns.com
Thanks
Charles
Old Feb 23, 2010 | 07:35 AM
B2autodesigns
Got a couple set of these available.
G35 Tein Tie Rods & Tie Rod Ends
Strengthened Tie Rod, Advanced Durability, Increased Steering Wheel Cut Off Angle, A Brilliant Option for Drifting! Tein Tie Rods and Rod Ends fit both the 350Z and the G35. Over 30% Stronger than the OEM equipment.
Please message me for best pricing.
Pm me with any questions.
Thanks
Charles
Old Feb 25, 2010 | 03:12 PM
B2autodesigns
The ISC coilover sleeves help protect your coilovers during harsh winter months. Sold as a pair. Two sizes 300mm and 370mm. Fits most coilovers.
$59.95 shipped for a pair.
Link to more information and to order:
http://www.b2autodesigns.com/index.php?cPath=13_24_1367
Thanks
Charles
Old Feb 27, 2010 | 02:17 PM
B2autodesigns
bump,
Thanks
Charles
Old Mar 1, 2010 | 02:25 PM
B2autodesigns
bump,
Thanks
Charles
Old Mar 9, 2010 | 08:52 PM
B2autodesigns
bump,
Thanks
Charles
Old Mar 12, 2010 | 12:44 PM
B2autodesigns
Lots of spring kits in stock!!!! pm me for pricing or any questions.
Thanks
Charles
Old Mar 14, 2010 | 03:51 PM
B2autodesigns
all pm sent
Thanks
Charles
Old Mar 14, 2010 | 05:31 PM
B2autodesigns
New lower pricing on Tein springs. Check first post for pricing
Thanks
Charles
Old Mar 16, 2010 | 12:04 PM
B2autodesigns
all pm sent
Thanks
Charles
Old Mar 19, 2010 | 01:33 PM
B2autodesigns
bump,
Thanks
Charles
Old Mar 22, 2010 | 04:52 AM
B2autodesigns
bump,
Thanks
Charles
Old Mar 24, 2010 | 11:17 AM
B2autodesigns
all pm sent
Thanks
Charles
Old Mar 26, 2010 | 09:55 AM
B2autodesigns
bump,
Thanks
Charles
Old Mar 30, 2010 | 06:25 AM
B2autodesigns
all pm sent
Thanks
Charles
Old Mar 30, 2010 | 10:17 AM
zerostyle's Avatar
zerostyle
hotchkis springs shipped to 76548
Old Apr 1, 2010 | 02:28 PM
B2autodesigns
all pm sent
Thanks
Charles
Old Apr 3, 2010 | 10:09 AM
B2autodesigns
all pm sent
Thanks
Charles
Old Apr 6, 2010 | 08:50 AM
B2autodesigns
bump,
Thanks
Charles
Old Apr 8, 2010 | 04:34 PM
B2autodesigns
all pm sent
Thanks
Charles
