Engine Intakes, Exhausts, Clutches, Turbos, etc...
UPrev Cipher and Osiris deals!
Old Mar 24, 2011 | 12:50 PM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Default UPrev Cipher and Osiris deals!
It's no secret. The Uprev reflash program is one of the hottest tuning options out there for the 350z / G35. No fuss or hassle with wiring in a piggy back and no need to tuck away a sloppy splitter harness for that expensive stand-alone.
We'll rock this deal as long as possible. PM or email me for special My350Z pricing!
UpRev Cipher Data & Diagnostics Cable - 03-06 Nissan 350z / G35
MSRP = $200
Cipher communicates using Nissan’s proprietary communication protocol which enables you to view data with more speed than generic OBDII scan tools giving the user better insight into how the vehicle is running. Sample rates of 20 times per second can be achieved on more than 15 sensors at a time.
SIMPLE ECU AND BCM CONTROL
Cipher also provides the user with basic dealership work support routines for the ECU and BCM including:
-Target Idle RPM+/-
-2 degree static timing adjustment
-Cylinder power testing
-Clear Learned Fuel settings
-Manual control of BCM functions, ie. Windows UP/Down, Activate Locks, Wipers, Lamps, etc.
-Fuel Pressure purgeEthanol Adjustments (if vehicle is equipped)
-Coolant Test
UpRev Osiris Tuner - Live ECU ROM Editor - 03-06 Nissan 350z / G35 MSRP = $700
Osiris Tuner is a licensed based system. The purchase of Osiris Tuner includes one license that will be transferred to the first ECU that is flashed. This vehicle can then be flashed as many times as the user wants, but the flash will not work on any different vehicles.
Osiris Tuner does not include any base maps or eTunes, the user is expected to develop their own tune for their vehicle using the stock ROMS included in the software package. Paid technical support can be found through UpRev’s Pro Tuners or through purchasing eTunes.
Parameters that are supported in the ROM Editor include:
-Up to 5 Maps on cruise control equipped vehicles
-Idle RPM
-Speed Limiter
-Electronic Throttle Control to achieve Wide Open Throttle at all speeds
-Rev Limiter
-DTC disable
-AFR Targets
-Fuel Compensation
-Ignition Timing Advance
-Cam Phasing for equipped vehicles
-MAF transfer function
-Cranking Enrichment and Ignition Advance
-Injector Latency
-K Fuel Multiplier
-Intake Temp
-Calculated Load vs. RPM
-Minimum Effective Injector Pulse Width
Old Mar 24, 2011 | 01:07 PM
ajcool2's Avatar
ajcool2
Pm sent
Old Mar 25, 2011 | 08:45 AM
ImportPartsPro
Pm's replied!
Old Mar 27, 2011 | 12:41 PM
ImportPartsPro
bump
Old Mar 28, 2011 | 08:12 AM
ImportPartsPro
bump
Old Mar 29, 2011 | 08:10 AM
ImportPartsPro
bump
Old Mar 29, 2011 | 08:14 AM
midz350's Avatar
midz350
PM price for upgrading to tuner version. Already got the cable.
P.S. sent you an email yesterday.
Old Mar 30, 2011 | 10:48 AM
ImportPartsPro
bump!
Old Mar 30, 2011 | 10:58 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
I just want to change my idle rpm, can I just use the cable for that or is there anything else i need? pm me price shipped to 90014
Old Mar 31, 2011 | 08:40 AM
ImportPartsPro
pm's sent, bump!
Old Apr 1, 2011 | 12:20 PM
ImportPartsPro
just got a bunch more in, bump!
Old Apr 4, 2011 | 07:42 AM
ImportPartsPro
bump
Old Apr 5, 2011 | 08:19 AM
ImportPartsPro
plenty more in stock!
Old Apr 6, 2011 | 07:08 AM
ImportPartsPro
bump
Old Apr 6, 2011 | 06:43 PM
Kuhan's Avatar
Kuhan
Do you have HR 350Z Tuner version? If so, how much shipped to 60018?
Old Apr 7, 2011 | 07:35 AM
ImportPartsPro
Yup, HR support is there. PM sent.
Old Apr 7, 2011 | 08:39 PM
Biggs_02's Avatar
Biggs_02
Does the cipher let me read the abs/bcm on 03 z's?
Old Apr 8, 2011 | 11:55 AM
ImportPartsPro
It works with basic BCM functions, but no ABS support currently.
Old Apr 11, 2011 | 09:10 AM
ImportPartsPro
bump!
Old Apr 12, 2011 | 07:38 AM
ImportPartsPro
bump!
