FS: Swift sport mach lowering springs
Old Jul 22, 2011 | 09:36 AM
asteffy's Avatar
asteffy
Default Swift sport mach lowering springs
Up for sale is a set of Swift Sport Mach lowering springs. The springs were cut slightly to lower the car a little more. It didn't affect them since they are rated and not progressive rate springs. Springs were great on the car and had an aggressive feel. People always thought the car was on coilovers. I'm asking $130 plus $20 shipping. Paid over $350 for these new. They were on the car about 10,000 miles. Pm with any questions. I will accept PayPal only. The one pic shows how my car set on these springs.
Attached Thumbnails Swift sport mach lowering springs-springbox.jpg   Swift sport mach lowering springs-spring.jpg   Swift sport mach lowering springs-aerosync.jpg
Old Jul 23, 2011 | 09:08 PM
BYBYCOP's Avatar
BYBYCOP
How is the ride quality compared to stock? Thanks.
Mike
Old Jul 24, 2011 | 06:05 AM
Cesar8783's Avatar
Cesar8783
Pm'ed
Old Jul 24, 2011 | 04:03 PM
asteffy's Avatar
asteffy
The springs ride slighty more aggressive. Def stiffer than stock springs.
Old Jul 27, 2011 | 03:44 AM
asteffy's Avatar
asteffy
Bump
Old Jul 27, 2011 | 11:43 AM
oni-kyan's Avatar
oni-kyan
So cutting them didn't effect them in any way?
Old Jul 27, 2011 | 01:10 PM
DerekW's Avatar
DerekW
Nice springs OP! I loved mine when I had them, more sporty and better ride quality. GLWS
Aren't those progressive? Cutting would change the rate range. Why not just buy the right sized springs?
Old Jul 27, 2011 | 03:59 PM
asteffy's Avatar
asteffy
They are not progressive rate springs so cutting didn't affect at all. Progressive springs wind tighter while these are the same ratio all the way.
Old Jul 30, 2011 | 09:51 PM
Gsedan35's Avatar
Gsedan35
Can you please post a picture of one of the front springs that you cut?
Based on the picture you posted of a rear spring I can calculate that you cut off about 3/4 of one loop. Takes the spring rate from 364lbs to about 427lbs. Not a deal breaker, 05+ cars have a 427lbs rear rate from the factory.
BUT, I need to see a picture of a cut front spring so I can run the same numbers.
Progressive springs don't have to have groupings of tightly spaced coils. It can also happen courtesy of changes in coil diameter. But your right, they are linear springs.
Old Jul 30, 2011 | 10:31 PM
nofrey's Avatar
nofrey
how did you calculate that?
Old Jul 31, 2011 | 09:10 AM
Gsedan35's Avatar
Gsedan35
Found a picture of a set of uncut Swift 350Z springs, that lets me count how many active coils the front and rear springs have. Knowing that, I can tell how much spring has been cut off.
Since Swift publishes what their spring rates are out of the factory, I can calculate what the spring rate would be based on how much spring was cut off. It's accurate give or take a few pounds.
When you remove the amount of active coils from a spring, spring rate goes up.
Old Aug 2, 2011 | 08:49 PM
asteffy's Avatar
asteffy
Whats your email i can send you pics of the front springs
Old Aug 5, 2011 | 02:37 PM
asteffy's Avatar
asteffy
New price bump! 100 plus 20 shipping
Old Aug 5, 2011 | 05:06 PM
dieselstation's Avatar
dieselstation
did you cut your rear spring mounts for the picture of your car? Or is that how the spring sat normally?
Old Aug 6, 2011 | 01:31 PM
asteffy's Avatar
asteffy
No didn't cut spring mounts.
Old Aug 6, 2011 | 08:59 PM
james struck's Avatar
james struck
I will take them! What else did you need to get your alignment back to spec?
Old Aug 8, 2011 | 02:04 AM
asteffy's Avatar
asteffy
Pm me. I just have a front and rear camber kit and was good with those springs.
Old Aug 10, 2011 | 07:26 AM
Gsedan35's Avatar
Gsedan35
Sorry I forgot about this thread, you have pm.
Old Aug 14, 2011 | 09:01 AM
asteffy's Avatar
asteffy
Bump
Old Aug 15, 2011 | 07:09 PM
JedixSole's Avatar
JedixSole
interested. pm me if still available
